Results 1 to 6 of 6
This is a discussion on Installed FMS Fmic kinked BPV line? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; So I finished up installing my FMS FMIC the other day after i blew apart my stocker, install was a ...
    Registered User Dgmftw's Avatar
    Sep 2012
    Ormond Beach
    So I finished up installing my FMS FMIC the other day after i blew apart my stocker, install was a bit troublesome with the crash beam and bumper, after the install I noticed that when i roll into boost and let off the car would buck/hesitate, also at WOT when running through the gears the car also bucks, quite annoying. I then performed a boost leak test found a few leaks which I then took care off, I still had the same issue, Eric Minehart suggested that the air from my BPV probably is not recirculating properly due to a slight kink in the return line, Ive tried reliving the pressure off the line to the best of my abilities, I still have the issue, what angers me the most is that the BPV line doesnt really seem to be kinked at all. Any suggestions??
    im running the forge BPV.
    Is it a BPV and not a BOV? So you're recirculating the air via the valve, not dumping it to atmosphere? And you've presumably relovated the valve to somewhere near the nose of the car? If so I don't find his suggestion unreasonable.
    Sep 2012
    Ormond Beach
    im not saying he is wrong, i just can figure out why? the FMS forge combo seems to be very common,here are some pictures
    Where is there a kink though?
    Sep 2012
    Ormond Beach
    exactly!!! so WTF is wrong, I have zero boost leaks, I pressurized the system to 25psi and used soap water, the valve is functioning properly, I even tried different springs
    So the valve is adjusted properly then? Hm... If he's certain it's the valve connections consider replacing temporarily the line with another and if possible make the other longer and so straighter, and see what happens? I don't know at this point.
