Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
This is a discussion on what would be the best decision? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Calvinball http://www.clubwrx.net/forums/tuning...-ecuflash.html Ok I read that but still leaves me with the question. Which and why.. im ...
    Registered User marz_wrx's Avatar
    Jan 2013
    Ok I read that but still leaves me with the question. Which and why.. im still new to this stuff so I dont know what all that means.. also I hear that aem is better than cobb intake due to cobb getting more hot
  2. #17
    Registered User Kwrxp's Avatar
    Aug 2012
    Spring Grove, PA
    Short throw is the first thing I did to my past 2 cars. It makes shifting more pleasurable, and as far as install goes. It is remarkably easy to do, the shifter part takes about 30-40 mins, but bushings will take a little longer because you have to get under the car. Still not bad though, and I know my TWM short throw came with step by step instructions that made it super easy.
    Go open source, it is cheaper and I have heard that it is just better all around.
    CBE is just a noise maker, go quieter if at all. I like the SPT just because it sounds stockish but "sexier"
    Intake or DP will require a tune, so if you get one of those it has to be tuned.
    '11 WRX DGM
  3. #18
    Aug 2012
    Spring Grove, PA
    .....oops
    '11 WRX DGM
  4. #19
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Quote Originally Posted by Kwrxp View Post
    .....oops
    I've done that. You can go back, edit your post and at that time delete it altogether. Then there's only the first one left.
  5. #20
    Jan 2013
    Well I think ima lean towards a short shifter and a tune... there anything besides whats mentioned that I should look into doing for my WRX?
  6. #21
    Jan 2009
    Md
    Quote Originally Posted by marz_wrx View Post
    Hmmmm this intrigues me... so can anyone explain tge differences between the opensource tune and accessport.. pros n cons.. and the differnce from AEM cai and cobb cai... I personally like the cobb intake more but I dont know much about the AEM.. wpuld like to hear from people who own these items
    As i've said many times... I use TP's maps, and Eric has A LOT of experience in tuning Subarus, so I asked him which intake he recommended and he told me flat out the AEM. The filter is completely outside of the engine bay and so the air stays constantly colder. People who have the cobb or some other SRI will try to scare you with that hydrolock BS, but the truth is, it only happens to morons who drive through water that's a foot or more deep. You shouldn't be doing that anyway. The SRI is mostly a waste of money IMO. The Cobb's box does allow for cooler air though, so that does help a little more than one without an air box. Also the size of the filter on the AEM is MUCH larger than the Cobb or pretty much any SRI which means more air will get pulled in. With the DP, I was told at the stage 2 TP map by Eric the AEM resulted in a 3-5% increase in power. He recommended it, I bought it... it was also MUCH cheaper.
    2012 WRX: TurboXS DP, AEM CAI, TP stage 2 tune
  7. #22
    Registered User bbrock171's Avatar
    Sep 2011
    Northern Virginia
    Quote Originally Posted by Methodical4u View Post
    Could not agree more. I'm also running TP Stage 2 with AEM intake. It's cheap, high quality, has a HUGE, very breathable filter and I don't plan on taking a swim any time soon so hydro lock is also not an issue. It also looks the best in my opinion; love that wrinkle red goodness.
    Plus I love AEM. I accidentally screwed up my filter on the initial install and AEM just sent me a new one at no cost.
