Results 1 to 15 of 18
This is a discussion on Cold startup Noise within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; 2004 WRX with cbe uppipe intake and a tune is making a noise when the temps drop below 20 deg. ...
    Registered User KenFerrari13's Avatar
    Jun 2012
    Harrisburg PA
    Cold startup Noise
    2004 WRX with cbe uppipe intake and a tune is making a noise when the temps drop below 20 deg. It almost sounds like a building pressure for something. Goes away after 30sec-1min. Starts fine, fluids full.
    Cold startup Noise
    Is it clacking or what?
    Jun 2012
    Harrisburg PA
    Sounds kinda like a building boost noise but at idle along with a slight grinding noise. I dont think its the turbo though just sounds kinda similar
    Mt. Laurel, NJ
    Take a vid and post it.
    There really is no way we can tell you what it is without actually hearing it.
    Jun 2012
    Harrisburg PA
    Thinking it might be the cai sucking in air at high idle at cold start
    Cold startup Noise
    The description could be a belt, tensioner, or roller; the latter two could be outside or inside the timing cover.
    Jun 2012
    Harrisburg PA
    I think it may be the cai in taking air on high idle but i guess could be the air pump?
    Jun 2012
    Harrisburg PA
    update: goes away if clutch is pressed in
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Interesting. Might be the throw-out bearing... When it warms up the noise quits, could be?
    Cold startup Noise
    Agreed throw out bearing. Not to worry until ambient temps go up, or if it does it all the time.
    Registered User twister8008's Avatar
    Aug 2011
    ND
    Cold startup Noise
    Both my new WRXs make a high whine sound when weather is really cold. (Below zero). The sound goes away after about 5-7 seconds. I think the turbos just hate cold weather...or North Dakota
    Yellow lights mean go faster!!!
    Mt. Laurel, NJ
    Quote Originally Posted by twister8008 View Post
    Turbos LOVE cold weather...they dislike hot
    Resident meany-rator 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    It could be the clutch pressure plate. I always thought the noise I had was a throw out bearing, then I replaced everything associated with the clutch and it made the same noise. Watched some Youtube videos, and turns out it was pressure plate/flwheel noise. While the noise is loudest with light weight flywheels, it is audible in stock form.
    Aug 2011
    ND
    Cold startup Noise
    Tell that to my car... She hates anything below -10F...
    Registered User mcdbrendan's Avatar
    Dec 2011
    Boulder, CO
    The noise you are hearing is the power steering pump. Mine does the same, and it's perfectly normal
