Results 16 to 30 of 33
This is a discussion on CARB Legal in California within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Ok, you're not gonna get a downpipe if you want something CARB approved. That's established. Get a stage 1 (pro)tune. ...
    Oct 2011
    Santa Ana, CA
    Re: CARB Legal in California
    Get a stage 1 (pro)tune. Third gen's can produce some extra power with just a stage 1 tune.
    Posted from a fone.
  2. #17
    Feb 2012
    Elk Grove
    Today was contacted by local tuning shop. He said TMIC won't pass smog. But upgrading the TURBO with good tuning is possible to pass smog. Although like other people have said, I don't have to worry about smog in 6 years. I also will need to add bigger injectors and fuel pump with protune.
    Other than the legal implication of catted DP, has anyone had problem with CEL long term. I heard this upgrade will help the most in increase power with proper tune.
    Upgraded:
    Turbo
    Injectors
    Fuel Pump
    Catted DP
    Protune
    Again guys, sorry for being a newbie when it comes to mods....I don't speak the language yet but still learning.
    Anyone have this set up and what gains you are seeing?
    2012 WRX PPB sedan
    Foglights installed, Arm-rest extension installed. Upgrades: Eiback F/R sway bar, Kartboy endlinks F/R, Cusco lower chassis brace, COBB AP stage 1 map.
  3. #18
    Resident meany-rator 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    The easiest route is this:
    •Catted DP
    •Tune
    ~$1000 or less
    That alone will get you a ton of power around +30hp +60 tq. After you get there, decide if you want more or not. Most people find it enough.
    I would not recommend a turbo upgrade out of the gate since you aren't close to maximizing the one in the car right now.
    And a TMIC Will pass smog, I did it with no issues. A FMIC may not pass smog.
  4. #19
    Feb 2012
    Elk Grove
    Quote Originally Posted by 06wrx4me View Post
    •Catted DP
    •Tune
    ~$1000 or less
    My brain twisted FMIC & TMIC....but you're right man.
    I got a quote:
    EQ Tuning
    COBB AP $595
    Catted Nvidia DP $522
    AEM CAI $275
    Walbro Fuel Pump $95
    Hall PRO RX MBC $100
    Tune $350
    Labor $350
    $2290.00
    I probably won't get TMIC for now.
    2012 WRX PPB sedan
  5. #20
    Jun 2006
    Nor Cal
    Quote Originally Posted by Mr2012WRX View Post
    I got a quote:
    EQ Tuning
    COBB AP $595
    AEM CAI $275
    Tune $350
    Labor $350
    $2290.00
    Not a huge fan of that vendor but a lot of people like them. And you don't need most of that. You could buy the AP, DP, install and flash yourself. That's the normal price on a tune, so he's not cutting you a deal.
    For comparisons sake give FW Motorsport, FLI, and GST a call.
  6. #21
    Registered User plasmarex12's Avatar
    Jan 2012
    so cal
    why so dead set on carb approved and passing smog? no offense but with your responses sounds like u need a carolla not a wrx. i still have plenty of bolt on things to do and consider my car a mild stage 2(tp stsge3 tune) and my car rips. im also in good old save the world california...
    boost is like alcohol, its fun and great in moderation, to much and something's gonna go boom.
  7. #22
    I always applaud CARB compliance.
    It shows manufacturers are serious about the quality of their products. If a maker doesn't care whether their part is legal, what else do they not care about?...
    It shows owners are serious about breathing. Before the current standards came into effect, there were days when the air was absolutely horrible. Now, even though there are more cars, there is less pollution.
    It's win-win.
  8. #23
    Feb 2012
    Elk Grove
    I just don't understand if you have nothing to offer here, you don't need to reply.
    I want to put the effort the learn as much and know the products that will achieve my goal doin it responsibly even if one or two individuals doesnt match their views.
    2012 WRX PPB sedan
  9. #24
    Feb 2012
    Elk Grove
    2012 WRX PPB sedan
  10. #25
    You already know the issue with live, on the street CARB problems: it can be very costly. So your practical problems are:
    Stealth while driving.
    Smog in 6 years or when you sell the vehicle.
    Breathing.
    The most reasonable compromise is a catted downpipe and tune provided the mufflers are not flashy. A turbo and injectors can fly under the radar but if heat shields are missing I'd notice. Id notice a TMIC too so one without logos might be a smaller gamble. An intake is too flashy. All this will cost extra because you should keep the original parts. The car will still be illegal but it won't scream it and you'll have a cat to reduce emissions.
    The new smog law requires a visual and a CEL check via OBDII. If your county smogs biannually that's what you'll face. The above could get you by. No guarantees.
    That's the bottom line IMO.
  11. #26
    Feb 2012
    Elk Grove
    Breathing.
    So ive decided I will be using catted DP (not legal) and AEM cai (CARB legal) with sticker number. I may have to wait for another year to upgrade TMIC (legal) and Turbo (can legal with proper tune). I think thats what I gather so far.
    So thanks for all your input.
    2012 WRX PPB sedan
  12. #27
    I don't think a turbo will be CARB legal but don't know. Ask the maker.
    You will probably need a tune for the intake plus DP.
  13. #28
    Jan 2012
    so cal
    i did offer you info, hint the reason behind my reply... dont be set on a turbo swap. A- your not going to pass smog, B- give the car a chance with a few bolt ons before doing major modding. my car still looks and sounds like a sleeper and other than my carb approved intake and tmic my car appears stock. the power from stock to my tp stage 3 is unreal for a few bolt ons. theres your helpful info. most def will need a tune for intake and dp. i agree with doing "the right" thing but when laws and the state cut back on recreation and fun then thats my issue. cali makes it harder and harder to do anything, from closing tracks, to restrictions on fuels, etc etc. all negative in my book...
  14. #29
    Jun 2006
    Nor Cal
    Why AEM CAI? The stock system is a cold air by design. If you buy one, make sure to get the Air bypass Valve.
  15. #30
    Mt. Laurel, NJ
    AEM CAI have been known to actually add some decent power gains with a proper tune on the GRs where as intakes don't do squat for our GD models.
