NEED HELP ... ARE THIS MODS GOOD ??? - Page 2
Results 16 to 30 of 40
This is a discussion on NEED HELP ... ARE THIS MODS GOOD ??? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by EJ257 Disagree, wholeheartedly, respectfully. A good set of headers will allow for quite a bit more power ...
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Re: NEED HELP ... ARE THIS MODS GOOD ???
    A good set of headers will allow for quite a bit more power while maintaining a comparable safety level vs the stock manifold. You should be able to run 2+° more timing with a "good ELH" (KBM fits into that description.
    Reapectfully I disagree. You know I am a huge fan of ELH, but the OP needs to consider basic braking/cornering mods long before considering ELH.
    I'm actually not really disagreeing with you, I just think the OP needs to focus on other components first.
    Beamed at your face at approx. 186,000 miles per second via DROID BIONIC
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Registered User SubaruWRC's Avatar
    May 2007
    New Orleans
    Like mikie had said rce springs and tockico struts are a good options. Turn in concepts sells these together in their legendary legend of totally awesome kits http://turninconcepts.com/product_in...oducts_id=1098
    That will be my next suspension mod. I have front and rear sway bars and endlinks now.
    Sent from my Nexus 7 using Tapatalk 2
    STU 17
    Hawk-Eye Alliance #117
    WATCH THIS
    Registered User mcdbrendan's Avatar
    Dec 2011
    Boulder, CO
    I'm not a fan of E85 for a DD. Anytime you're not in need of the extra octane, you're pissing money away. This is why I'm such a proponent of methanol injection. Pump gas when you need it, race gas when you need it.
    IIRC E85 is almost always 10-15% cheaper than gasoline. Can someone correct me if I'm wrong?
  6. #19
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by mcdbrendan View Post
    It also has 30% less energy density, so you're spending more money per joule.
    Facebook me here
  7. #20
    Hell on Wheels Rodman's Avatar
    May 2012
    CT
    Amazingly, my OEM clutch still has not slipped.
    Bet that's because you know how to drive a manual.
    Rod
    2014 WRX SWP Premium sedan
    Stink-Eye Mob #57
    "Just remember, with great power comes great responsibility" - rarrior
  8. #21
    Dec 2011
    Boulder, CO
    Noob question here, sorry in advance: with a lower energy density, why are e85 tunes consistently making more power? And how would that effect the wallet?
  9. #22
    Palmyra, NJ
    Ahhhh because that is always stated on the pump, right?
    Damn Physics nerd
  10. #23
    Jan 2012
    Philly Area
    E85 actually has a much higher octane rating than regular petrol. Tuners can use this to their advantage to increase power. /short-oversimplified answer
    I'll let the more technical response be provided by someone more qualified
    - Will
  11. #24
    Octane and cooling. You can run a more aggressive tune.
    The problem is that you use 30% more E85 than you would with pump gas.
    Resident Tuner @ WTF Tuning
  12. #25
    He's getting a custom tune, why not install the headers on there in prep?
    While I agree with you on needing to address other stuff, it's going to be a bolt-on stock turbo car. It's not as imperative as someone doing a turbo swap. If it needs to wait a bit, NBD. That said, the other components are addressed by the clutch/flywheel budget he just saved himself
  13. #26
    Dec 2011
    Boulder, CO
    I knew the octane is much higher, didn't realize the tune could be that much more aggressive though due to the lower chance of detonation. Thanks for the info. Sounds like it won't effect my pocket book directly, but the supporting mods certainly will.
  14. #27
    Dec 2011
    Pottstown PA
    this mods are good. my stock clutch has 94k not slipping yet.
    Marky Mark
    My bugeye build
    MinoskePhotography
  15. #28
    E85 isn't that prevalent in my area, so we'll go on your use of 10-15% cheaper than gas. Let's use some simple numbers to put things in perspective...
    Gas: $4/gal
    E: $3.50/gal (12.5% cheaper)
    Gas: 300 miles/tank
    E: 200 miles/tank
    Typical 1,000 miles/month
    Typical 15 gal/fillup
    50 gallons of Gas = $200
    75 gallons of E = ~$260
  16. #29
            MainFrame's Avatar
    Austin, TX
    That depends entirely on fuel prices in your area. It's actually cheaper per mile for me to run e85 (just barely). Plus you have to consider that most cruising and daily driving isn't actually going to use +30% for e85.. highway driving is more like +10% fuel consumption compared to 93. If e85 wasn't $2.42/gallon it would be a different story..
  17. #30
    Dec 2011
    Boulder, CO
    Well that explains it: this whole time I've incorrectly assumed E would have the same mileage...
