Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
This is a discussion on Heat shields..... Worth it? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Methodical4u Did you notice your temps down after installing both? Also, the issue i've read is that ...
    Quote Originally Posted by Methodical4u
    Did you notice your temps down after installing both? Also, the issue i've read is that a turbo blanket will take away from the turbo life. No?
    Turbos are cheap enough. Especially with a TMIC car, a turbo blanket is worth any reliability issues you may encounter. With a FMIC car, it's a bit less of an issue, but I'd have no hesitation putting one on my car...
  2. #17
    zax
    zax is online now
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Re: Heat shields..... Worth it?
    Lower temps isn't really the point.. the performance to be had is mainly from retaining higher temperature within the exhaust and turbine housing. Keeping the heat in the exhaust and housing preturbo maintains exhaust gas velocity, which spins the turbo.
    I've never heard of reliability concerns with using a turbo blanket. I would think if anything it would improve reliability because it will extend the cooling period for the turbo. Quick, drastic temperature fluctuations are detrimental to turbo life (and pretty much any material).
    ^That. Besides, I have no way of directly measuring underhood temps.
    Beamed at your face at approx. 186,000 miles per second via DROID BIONIC
    Facebook me here
