Page 1 of 4 1234 LastLast
Results 1 to 15 of 51
This is a discussion on How much boost will the 11's - 13's turbo efficiently produce? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I'm just wondering what the max for these turbos is. I'm at 20 and a little over here and there. ...
    Jan 2009
    Md
    I'm just wondering what the max for these turbos is. I'm at 20 and a little over here and there. I don't know with a TMIC, FP, DP, CAI, 3 port, and OTS tune what else I could add to get that little bit more power, headers are out of the question... to much trouble... just not happening. A protune is 500.00 and I have no clue how much more that would net me over the stage 3 TP tune.
    2012 WRX: TurboXS DP, AEM CAI, TP stage 2 tune
    Moderator Donkey's Avatar
    Da boonies
    IHI doesn't publicly publish their compressor maps. That being said fuel is the main contributor to more boost. Higher octane/E85 or meth injection is really the only way to get more without turbo modification. Or get the turbine wheel clipped or change the turbine housing to a P20 but injectors will be your limitation. If you are looking for more power try TGV deletes,ported/polished exhaust manifolds or a lightened crank pulley.
    2002 FORESTER S
    1998 FORESTER S
    May 2010
    Pittsburgh, PA
    IHI doesn't publicly publish their compressor maps. That being said fuel is the main contributor to more boost. Higher octane or meth injection is really the only way to get more without turbo moddification. Or get the turbine wheel clipped or change the turbine housing to a P20. If you are looking for more power try TGV deletes,ported/polished exhaust manifolds and a lightened crank pulley.
    I'm surprised you mentioned a lightened crank pulley. Any reason why a lightened crank pulley and not a flywheel?
    2011 STi Build Log
    Da boonies
    Cost and ease of installation.
    Sent from my magic banana
    2002 FORESTER S
    1998 FORESTER S
    Jan 2009
    Md
    What's a TGV? What about an EWG? Or is that really needed?
    zax
    zax is offline
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    PSI
    Facebook me here
    Da boonies
    Quote Originally Posted by Methodical4u View Post
    EWG isn't going to get you that much more boost but could get you alittle more topend. TGV= Tumble Generator Valve.
    GrimmSpeed
    2002 FORESTER S
    1998 FORESTER S
    Gold Member lokey's Avatar
    Jan 2011
    Crofton, MD
    Greg
    www.modmeets.com
    ProTuned Stage 3 '11 WRX Ltd HB (SWP) ~ 342 awhp 399 ft-lb tq on E85
    Mods Blog Post
    Friends don't let friends drive Mitsubishis.
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by lokey View Post
    Facebook me here
    Jan 2011
    Crofton, MD
    Nom-nom.
    Greg
    www.modmeets.com
    Mods Blog Post
    May 2010
    Pittsburgh, PA
    Good point. I always feel they get a pretty bad wrap. I personally am just too cheap to try a pulley. I'd love a nice lightweight flywheel though when I do my clutch. That wait for the revs to drop between first and second is a killer =P
    Your EWG setup will come close to a set of equal length headers all said and done. It does make it much easier to tune once you get your turbo dynamics dialed in. I got mine due to some boost creep issues with my catless down pipe.
    Nom-nom.
    Yeah, no joke. Now I want a darn corn dog.
    2011 STi Build Log
    Jun 2012
    does this require a tune? and when would something like this be needed? any gains at stock or stage 1-2 that would be noticeable?
    May 2010
    Pittsburgh, PA
    Quote Originally Posted by rickyd13 View Post
    Are you speaking of the crank pulley? No tune. it's a driveline modification. It would act like a very slightly lighter flywheel, provided I'm not off my rocker. No measurable hp difference.
    2011 STi Build Log
    Jun 2012
    sorry i quoted the wrong post i was talking about the grimmspeed Tumble Generator Valve (TGV) Delete Service thats how they have it listed it was in donkeys link
    Jun 2012
    but also gains on the pulley would be nice
