How much boost will the 11's - 13's turbo efficiently produce? - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 51
This is a discussion on How much boost will the 11's - 13's turbo efficiently produce? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by rickyd13 sorry i quoted the wrong post i was talking about the grimmspeed Tumble Generator Valve (TGV) ...
    May 2010
    Pittsburgh, PA
    Quote Originally Posted by rickyd13 View Post
    sorry i quoted the wrong post i was talking about the grimmspeed Tumble Generator Valve (TGV) Delete Service thats how they have it listed it was in donkeys link
    It varies with current horse power. If you are on a newer 2.5L, I've seen about 10hp across the power band. You'll need a tune or some way of disabling check engine codes to delete them.
    but also gains on the pulley would be nice
    As stated, no direct horsepower gain. Lighter drive line.
    2011 STi Build Log
    Jun 2012
    thanks
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    You can remove the motors and plug them in, to "disable" the code, but I prefer to disable the code in the ECU itself.
    If there is any gain in usable power, I've not seen any evidence to support.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  6. #19
    Moderator Donkey's Avatar
    Da boonies,Va
    Lightened pulley works the same as a lightned flywheel. For every 1lb you remove from the crank it is like removing 10lbs from the weight of the vehicle. Off boost throttle response is pretty noticeable especially once the car is in motion. Faster rev's=faster powerband. I like them and they are easy to pick up used for $50-$60. Removing weight from a vehicle doesn't increase HP but is the car faster? Absolutely..........
    2002 FORESTER S
    1998 FORESTER S
  7. #20
    Da boonies,Va
    Their link has the expected gains listed in it I thought. Yes a tune to disable the codes at the least is needed as stated earlier.
    2002 FORESTER S
    1998 FORESTER S
  8. #21
            MainFrame's Avatar
    Austin, TX
    I ran 23.5psi on 93 octane with my vf22. I could have turned it up a little more, but at 23.5psi the IWG was being forced open. Of course that was with a lot of other mods..
  9. #22
    Jun 2012
    i saw that it said the gains but i meant are they noticeable?
  10. #23
            MainFrame's Avatar
    Austin, TX
    TGV deletes are well worth it, and you might as well throw in phenolic spacers while you have the manifold off.
  11. #24
    Jun 2012
    thanks i also just posted a thread with a few questions if anyone can help sorry OP not trying to thread jack just curious
  12. #25
    May 2010
    Pittsburgh, PA
    Keep in mind, this mod requires basically removing the manifold. It's not really an "easy" mod, and there are some pretty good bang for your buck mods that you can do first.
    Otherwise, I haven't personally done the modification myself. I wouldn't expect a night and day difference to say the least.
    2011 STi Build Log
  13. #26
    Jun 2012
    thanks
  14. #27
    Quote Originally Posted by Methodical4u
    headers are out of the question... to much trouble... just not happening.
    I'm lost on how a set of headers is "too much trouble"...
    I'll just leave this here:
    NASIOC - View Single Post - TopSpeed Motorsports - **2011 STI** Invidia Race Header Tested!!
    Resident Tuner @ WTF Tuning
  15. #28
            MainFrame's Avatar
    Austin, TX
    Yeah, it's not going to be a huge difference, but I still feel it's worth it. Since you have to remove the manifold, and obviously you're going to have to have the car professionally tuned to take advantage of the improved VE it's not something that is normally done just by itself.
    When I had my TGVs removed and ported I also port and polished my throttle body and intake manifold, as well as installing phenolic spacers and +1mm valves with a radiused valve job. The most noticeable difference was off boost drivability. Fuel economy went up probably 3-4mpg and the car was much easier to drive around town.
  16. #29
            MainFrame's Avatar
    Austin, TX
    lol... one of the easiest mods to do, too much trouble
  17. #30
    Jan 2009
    Md
    Quote Originally Posted by lokey View Post
    yes, this would be nice, but it's 45 minutes in both directions for me to be able to get to it, so i've got to make it on 93 for a while.
    2012 WRX: TurboXS DP, AEM CAI, TP stage 2 tune
