Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
This is a discussion on Air to Fuel Ratio - CAI before and after within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Heide264 Post up some logs, including long term/short term fuel trims from the ECU then. I'd be ...
    Turtles and Penquins 11blackSTi's Avatar
    Nov 2012
    MAINEiac
    Post up some logs, including long term/short term fuel trims from the ECU then. I'd be curious to see the fuel trims through the power band. I'd be surprised if it actually matched up across most of the MAFV range. I had a lot of issues in between 2-3V when adding my intake.
    The irony of the situation (if I am not off my rocker): If the car didn't use fuel trims to compensate for a fueling error, and the MAF housing is the same diameter, then you didn't gain anything by going with the intake. Same MAFV, same voltage, same fuel, same burn ratio.... Same air flow. This applies to everything - WOT response, low load cruising, and while in transient.
    At work right now, so I can't post anything currently. My air/work ratio is not looking very good currently
  2. #17
    Registered User EndlessSea's Avatar
    Nov 2012
    Las Vegas
    so many intake haters on this forum. i find the hate comical actually.
  3. #18
    zax
    zax is offline
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by EndlessSea View Post
    I think you're confusing "hatred" with knowledge. Specifically the knowledge that slapping an intake on a car and not scaling the MAFv on a Subaru is rarely EVER a step in the right direction. Do you have anything else to add?
    Facebook me here
  4. #19
    May 2010
    Pittsburgh, PA
    I personally have a cold air intake. I don't hate them by any means.
    On the other hand, I do hate general ignorance (even though I am admittedly guilty of it occasionally and incidentally, as we all are). Assuming that throwing an intake on will be "okay" is, at this point, general ignorance. I can go into detail as to why it's dangerous with the newer ECUs, but I doubt anybody would listen anyhow (outside of those that already know).
    Rescaling the MAF is simple and should be done, in my opinion, even when it was not your intake that changed. VE changes in these cars are done using the MAF scaling (in some way/shape/form). It's easy. Your fuel trims can cover up an issue for a little while, and maybe 99% of the time, but that isn't all inclusive.
    It's like wearing protection... 99% of the time you will probably be okay... That 1% will cost you though.
    2011 STi Build Log
  5. #20
    Texas, United States
    haters = people who use tools such as math and science to make informed decisions
  6. #21
    zax
    zax is offline
    Nov 2008
    While not ideal by any means, it's a start: HOWTO: One Man's Way of Scaling a MAF - NASIOC
    wow. You just compared an STi to, well, an STI!
    EndlessSea, I've owned 4 intakes over the years. I don't consider myself at all a "hater," unless it refers to the definition proposed by MainFrame.
    Facebook me here
  7. #22
    Moderator Donkey's Avatar
    Da boonies
    I think my next upgrade might be a manual or elecontrol boost control to see if I can get the AFR leaned out a little (high 11's maybe?) to get a little more power, as 11 seems a bit rich.
    Any thoughts?
    This would be a step in the wrong direction,considering a boost controller is used to control boost,not AFR's. Low 11 AFR is fine on a Subaru.
    2002 FORESTER S
    1998 FORESTER S
  8. #23
    May 2010
    Pittsburgh, PA
    Do you mean to infer that pushing the car to a (conceptually) higher load doesn't make the car run leaner? Blasphemy. Everybody runs leaner AFRs at higher loads =P
    2011 STi Build Log
  9. #24
    zax
    zax is offline
    Nov 2008
    If that was sarcasm, you forgot the orange. I seriously doubt that an intake would put the car into untuned load cells. Yes, the EBCS may (and probably will), but depends on how aggressive you tune your WGDC.
    Facebook me here
  10. #25
    May 2010
    Pittsburgh, PA
    It was sarcasm. Was geared towards the idea of using higher boost levels to raise your AFR. Nothing to do with using "untuned" load cells, just the fact that going to higher load isn't gonna raise your AFR.. just move you over in the table a bit to around the same AFR.
    2011 STi Build Log
  11. #26
    OK so, again thinking out loud... what should the OP do at this point? My gut feeling is (a) nothing and (b) post logs.
  12. #27
    May 2010
    Pittsburgh, PA
    Post logs (or better yet, graphs).
    1.) WOT pull with target fuel and wideband o2 across the power band. Include A/F Learning as well.
    2.) Include a plot of AF correction + AF learning over MAF(V) for a longer drive (maybe 30 minutes if possible)
    2011 STi Build Log
