a different way to get rid of boost lag? - Page 5
Page 5 of 5 FirstFirst 12345
Results 61 to 72 of 72
This is a discussion on a different way to get rid of boost lag? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I think the Daytona was sortof the precursor to the Talon/Eclipse. I think they took the chassis from the later ...
  1. #61
    Q RayfieldsWRX's Avatar
    Oct 2002
    The Old Folks Home
    I think the Daytona was sortof the precursor to the Talon/Eclipse. I think they took the chassis from the later Daytona's or something like that.
    --Ray
    "Bro ima get Bimota BB3 because expert. My parents have 911 turbo but awd won't let me launch, ima get 962 twin turbo Group C bro." -- SD_GR
    2013 Subaru BRZ Limited
    2002 Subaru WRX Bugeyebrid Wagon -- SOLD
    2002 Subaru WRX Sedan -- SOLD
  3. #62
    Registered User tirerob's Avatar
    Nov 2012
    bug-eyeing in the Bakken
    Oh heck ya. Sorry I really did know that....I'm just on my first coffee of the usual four by now. Leeeetle slow this morning.
    Do the variable vane turbos alter the pitch of they're blades like a helicopter or do they change the compression chamber? I've never really looked into it but we just had a ford eco boost Taurus in for tires.
  4. #63
    May 2010
    Pittsburgh, PA
    Quote Originally Posted by tirerob View Post
    There are many different ways to incorporate variable geometry turbines. Most of them use a 'flapper' or wiper arm to alter the AR or the angle of attack on the turbine I believe. I don't know of any that actually change the blades at all. Again, a waste gate (such as the one in a Subaru and most other gasoline powered turbo cars) is an example of a variable geometry turbine.
    2011 STi Build Log
  6. #64
    zax
    zax is online now
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    IIRC, the most common form of VGT implementation is using a nozzle to direct the exhaust across the inducer through the exducer... this effectively changes the A/R of the turbine allowing quicker spool. Effectively like a 7cm^2 housing at low load and a 9cm^2 housing at high load.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  7. #65
    Nov 2012
    Getting a quicker boost level in a smaller chamber then changing to more volume at pressure in the higher load/rpm range? Makes since to me, kinda. I'm sure there is a million different things I'm missing though lol. But with adaptability like that would it make it harder or easier to tune on a engine like ours? Just bolting up a bigger turbo doesn't seem to me like it would perform( at the same levels) as well as a smaller variable turbo. Although no denying the punch of the bigger( maybe higher volume? I'm no expert for sure) turbo
  8. #66
    May 2010
    Pittsburgh, PA
    Re: a different way to get rid of boost lag?
    The downside to variable geometry turbos is the complexity and cost involved upfront, as well as the fact that you now need a control system of some form.
    Take the waste gate as an example.
    Without it, you simply bolt up a well specified turbo to an engine and let it go. This is more in the industrial and diesel world.
    Now in a gasoline engine, you have a larger operating range over which you want the turbo to be efficient. Hence, they spec the turbo to a smaller output, and make the turbine overly large to limit it back out if it's efficency volume.
    2011 STi Build Log
  9. #67
    Feb 2013
    Columbia SC
    Let's not forget how the supercharger works also. Ya you won't have turbo lag but u don't make all your power till your about to shift. When our turbo spools up, u get ALL your boost right then and keep it throughout the rom range till u shift, or if you have an auto! Till u let off the gas
  10. #68
    zax
    zax is online now
    Nov 2008
    Quote Originally Posted by elblanco1987 View Post
    Not quite true. A twin-screw supercharger or a twin-lobe supercharger (roots blower) makes boost linearly with rpm (when the compressor is correctly matched to engine size). That is, max boost arrives at max rpm where the car has the potential to make the largest power. This mimics the powerband of a NA car. A centrifugal supercharger offers increased simplicity and improved adiabatic efficiency, but boost is built exponentially to RPM. Consequently,a turbocharger makes boost only over a very specific airflow band. No WRX built OEM holds boost to redline, like a properly designed blower. However, few superchargers charge the incoming air to the pressure a turbocharger does...
    Sent from my Nexus 7 using Tapatalk HD
    Facebook me here
  11. #69
    Feb 2013
    Columbia SC
    That's what I was trying to say lol
  12. #70
            MainFrame's Avatar
    Austin, TX
    No WRX built OEM holds boost to redline..
    That's what the 35r turbine wheel is for.
  13. #71
    zax
    zax is online now
    Nov 2008
    Size queen.
    Beamed at your face at approx. 186,000 miles per second via DROID BIONIC
    Facebook me here
  14. #72
    Jan 2012
    Philly Area
    Size queen.
    - Will
