Intercooler to Throttle body hose leak
Results 1 to 8 of 8
This is a discussion on Intercooler to Throttle body hose leak within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I recently flashed too stage 2, and upon having Eric look at datalogs, found out i have a boost leak. ...
    Jan 2009
    I recently flashed too stage 2, and upon having Eric look at datalogs, found out i have a boost leak. Probably at the intercooler connection.
    1. Why on earth is this so common?
    2. What was everybodys fix? I've heard t bolt clamps, new hose, removing done rubber caps that leak.
    I really can't believe Subaru has never fixed this issue
    Sent from my Motorola RAZR MAXX using Tapatalk 2
    Registered User gregroot198521's Avatar
    Feb 2011
    El Paso, TX
    If you have a 3rd gen WRX, you're in luck, I have a Tomioka IC-TB hose for sale.
    Hawkeye Alliance #1050
    Build Thread
    http://i1108.photobucket.com/albums/...ps665d9b9d.jpg
    Always dirty, never scurred......
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Now hold on, let's go over this slowly. Boost/vacuum leaks are exceptionally difficult to diagnose, and jumping to a conclusion regarding the location of the leak will only leave you tired and frustrated. If you have a 3G WRX, it's more likely that you have a leaky BPV that's causing issues. How did Eric ascertain that you had a boost leak?
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Jan 2009
    Re: Intercooler to Throttle body hose leak
    The data logs i sent him. I'm just going with his call as he is a tuner & i trust his call. I'll try all available options however
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by PhoebeusFenix View Post
    OK... so what's your question? I am very familiar with Eric Mines' work.
    Unless you have pressurized your intake, I really would NOT assume that the leak is in that particular location, even if it is common. The leak may be there, or it may not be. My recommendation, if you feel that you have a boost leak, is to pressurize the intake and use a vacuum hose to listen for leaks. You can build tn afta-maf blockoff from basic materials an Home Depot or Lowes and use a basic shop compressor to pressurize the intake. This will save you a LOT of time, headache, and money spent on parts you may not need.
    Facebook me here
    Palmyra, NJ
    If it is in fact a leak at that connection...perhaps you could just tighten it down a bit? Little obvious to me...
    Jan 2009
    I'll look into that! Would be nice to have a definite leak location.
    Jan 2009
    The reason i posted this is because of the research I've done this is a fairly common problem with this hose.
    Was just looking for possible fixes so I'd one doesn't work, I've got another avenue of troubleshooting.
