Results 1 to 10 of 10
This is a discussion on CNT Downpipe? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I've been researching down-pipe options and found CNT. It is the least expensive catted DP by far, but does anyone ...
    Registered User younoleit's Avatar
    May 2012
    CNT Downpipe?
    I've been researching down-pipe options and found CNT. It is the least expensive catted DP by far, but does anyone have an opinion or experience with it?
    I had fitment issues with the '08 WRX I put one on.
    May 2012
    Ahh thanks for that. You get what you pay for. Was hoping to save some money, but I suppose with something this critical it'd be a bad idea to do it the cheap way. Looking at Nameless because I have their Axle Back but slightly putt off by the price and hearing mixed things about divorced gate.
    Registered User blusubi02's Avatar
    Jun 2011
    Appleton wi
    i have one on my 2013 wrx and it fit perfect no problems at all been on there only 500miles so far but all is well
    2013 WRX Premium SWP HB Stage 2
    1976 Corvette Stingray black
    2008 WRX Basic CBS HB TRADED IN
    2002 WRX Basic WRB SOLD
    Registered User speedtown's Avatar
    Feb 2012
    VT
    2010 rex and I had fitment issues as well. Had it for around 5k miles and no issues other than the fitment that was mentioned.
    Jun 2012
    Boca Raton, FL
    I have one in my '12 WRX. It was harder to fit then Invidia, but it does fit and it's well made. Also check out Tsudo
    May 2012
    Quote Originally Posted by Mf645 View Post
    Any boost creep issues?
    Jun 2012
    Boca Raton, FL
    Not at all. Pro Tuned and it hits 18.7 PSI and tapers off slightly as the RPM builds, ending up around 15.5 at redline. The highest peak boost recorded is 19.1 PSI. The car is 100% stock except for the DP, tune and SPT heat shield
    Registered User EPA H8R's Avatar
    Jan 2013
    Mine fit well, no problems so far. I have full CNT turbo back and their catless up-pipe. The only issue I had with any of it was the stock EGT probe didn't fit in the up-pipe, so I had to modify it a bit but it worked in the end.
    Jan 2009
    Re: CNT Downpipe?
    Just installed last night. Easy, quick install. Amazing results.
    Sent from my Motorola RAZR MAXX using Tapatalk 2
