Results 1 to 14 of 14
This is a discussion on Next Mod - Stage 2 (2011 WRX)??? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I currently have a 2011 WRX Hatch running stage 1 OTS 91 map. I have about 00. I'm debating wether ...
    Jul 2012
    San Jose
    I currently have a 2011 WRX Hatch running stage 1 OTS 91 map. I have about $2000. I'm debating wether to go full stage 2(Invidia Q300 CBE, Invidia CDP & SF intake) or go the suspension route. I would probably keep stock wheels for now, and go struts, coils, and sways. I just want some general input from people with experience on handling vs. power. Also if you have any suggestions on any other exhausts or suspension stuff please add your thoughts!
    - 2011 WRB WRX Premium Hatch
    Registered User jsBLwrx's Avatar
    Oct 2012
    MD
    Re: Next Mod - Stage 2 (2011 WRX)???
    It would seem you are leaning towards a complete sus mod.
    IMHO a stage2 mod will over power any stock sus and break systems
    I've updated my breaks and sus before going stage2...... Since then i feel that the mild tweaking to the suspension system would need to be addressed if I was planning any auto-x
    As a DD the combo is ok......
    Texas, United States
    I think it really depends on how you drive it and where you personally feel the car is more lacking. If you asked a pro driver I'm fairly certain they would say suspension suspension suspension ..
    Jul 2012
    San Jose
    I definitely notice some pretty bad body roll, but then again the stock exhaust is so quiet. I'm thinking of doing both, but my budget is a very limiting factor. What do you guys think the best first suspension mods are, to get the best bang for your buck?
    Jan 2012
    Philly Area
    Quote Originally Posted by briancox33 View Post
    Sways and endlinks.
    - William
    Registered User jeremydingeman's Avatar
    Mar 2012
    Bothell, WA
    Ive really found that the novelty of the exhaust wore off quicker than i thought it would. Sways and endlinks are a great suggestion
    Find a low-mileage one-owner unmodified '04/'05 and you're golden.
    Understeer is when you hit the wall with the front of the car.
    Oversteer is when you hit the wall with the rear of the car.
    Horsepower is how fast you hit the wall.
    Torque is how far you take the wall with you.
    Oct 2012
    MD
    Sways and endlinks.
    ^^^ This. Body roll and the brakes bothered me enough to upgrade a little after a month. 2013 sedan.... I went with the whiteline 24/22mm hvy/dty adjustable fr/rr swaybars and the endlinks. I've also added ss braided brake lines and performance break pads
    Body motion and front end feed back are unblieveable
    Stage2 tuning is speechless
    Registered User wrx650's Avatar
    Feb 2012
    Cleveland, OH
    What about doing a bit of both? Sways and endlinks will make a huge difference in the handling and body roll. You could do those plus a full tbe for your budget. I went with the rallitek track spec package which is 25 mm front and 22 mm rear plus their hd endlinks and I am really happy. If you did the q300, dp, sway bars, and endlinks, you would definitely have enough money and maybe enough for an intake, too.
    -Noah
    2009 Spark Silver Metallic Sedan - Stage 2+
    Build Thread: http://www.clubwrx.net/forums/builds...wrx-sedan.html
    Jan 2012
    Philly Area
    ^ That.
    Why put all the money into one facet of the car, and leave the other "deficient." I didn't want to jump in and say "mod the same way I will!!1!" but I will still share my thoughts/plans.
    I find the stock tune to be quite not smooth, and wouldn't mind a little bump in powah. Ok, stage 1 and possibly stage 2 down the line.
    I find the stock suspension to have too much body roll. Ok, sways and endlinks.
    I don't hate the stock shifting, but it could certainly be improved. Ok, short shifter.
    And eventually, I will want better sound. Ok, aftermarket head unit.
    Point being, there are aspects of the car that I personally feel could be improved. Since you are debating suspension vs powah, I assume you feel that those are areas that could be improved. $2k will easily put you at stage 2 with at least some sways and endlinks even if you go with more expensive options, so why not hit both at the same time? You can always do more later if you still feel an area is lacking.
    - William
    Registered User MercRising's Avatar
    Mar 2012
    Denverish
    I spent under $1000 for a Tactrix cable, 3" catless turbo back exhaust, EBCS, intake, rear sway and links, then a stage 2 Torqued Performance map. I did spend about another $1000 on wheels and tires but, I'm still at your $2k. Included in that amount I've also done a variety of bushings, group-n trans mount and positive shift bushings, dif bushings etc... Granted, all most all parts were used and I did the installs myself but, for about $2000 is exactly like if not better than cars that guys have spent 2 times the cash on all brand new parts and had somebody else doing very simple installs.
    I say spend your 2k on an Open Source stage 2 and some type of handling..aka sways and/or wheels-tires!
    You won't be sorry, just do your reading and ask guys that have done it already.
    Good luck with it all, it's a great way to waste your hard earned money..I should know!
    Registered User kprugbyplaya's Avatar
    Nov 2012
    Lansdale, PA
    PERRIN Performance — — Subaru 2011 WRX Sway Bar Combo Kit
    ^That is a pretty good deal. You get the whole kit.
    Get a STS as well.
    See how you like that. If you want more, then go for struts and springs
    Feb 2013
    sell wrx, aquire sti
    Mar 2012
    Denverish
    Quote Originally Posted by charlie_hustle View Post
    He meant 911!
    Registered User mgmoehn's Avatar
    Jun 2012
    Peoria Area - IL
    Pretty sure you would save about 600 dollars just by going with a cheaper exhaust and dp...
    the DP is JUST a pipe... and a hi flow cat. I would go for a CNT catted DP. The exhaust noise is different between systems... but the Invidia one of the most expensive systems... do some youtube and sound clip searches for possible cheaper options for sound.
    Go OTS Opensource... I did and it is awesome..
    If I had 2000 to spend on exhaust and sways (2 things I am debating over now but dont have 2000)... I would go CNT Racing Catted DP/CNT HB Exhaust/Stage 2 tune Opensource/Eibach Sways/Kartboy Endlinks...
    ALL FOR UNDER 2000
    2012 WRX Hatchback ISM - Base Model - STI STS, SPT Boost Gauge, AEM Intake, TP Stage 1 Tune, red illumination kit, cobb shift knob, 20% tint - currently on stock wheels wrapped in Pirelli Winter Carving Edge Tires
    Some cool tidbits to come...
