Results 1 to 15 of 26
This is a discussion on Up pipe, 3 point boost control? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hey everybody, installing my up pipe today. I bought I 3 point boost control with it, Any opinions on it? ...
    Registered User skinikko's Avatar
    Jul 2012
    Utah
    Hey everybody, installing my up pipe today. I bought I 3 point boost control with it, Any opinions on it? Likes or dislikes?
    Sent from my PG86100 using Tapatalk 2
    Sammich Makin' Princess Leia wrxtreme06's Avatar
    May 2007
    orlando flawduh
    What type of Subaru do you have? Assuming 04-05 based on your avatar. What type of engine management do you plan on using with the boost controller
    desiree
    06 impreza wrx tr
    : cobb stage II - protuned by STi_Mikey!
    hawk-eye alliance #11:11 //
    wingl3ss @ll!ance #17 // lvl 80 N.E.R.D.
    facebook
    Mt. Laurel, NJ
    Quote Originally Posted by wrxtreme06 View Post
    This.
    Otherwise, replacing the UP is a solid idea. Any other mods? No need really for a 3port BCS unless you are planning on further modding (stage 2 and such).
    zax
    zax is online now
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    I disagree. An interrupt-type EBCS will benefit anyone in any stage of modification if you have the patience to tune for it. Granted the spool on the TD04-13T is exceptionally fast, and the spool improvement will not be as drastic as on a larger turbo, but there will be gains.
    OP, as mentioned, the 3-port (interrupt-type) EBCS will require tuning your WGDC and Turbo Dynamics. You will REQUIRE engine management.
    Facebook me here
    Mt. Laurel, NJ
    So case in point...what is the point of doing all that unless you plan on modding further? You just like to disagree with everything I say, jackass.
    zax
    zax is online now
    Nov 2008
    No, I'm saying if you have it and you install it, there will be improvements in spool and boost control. Even if there are no further mod plans, it's a good upgrade.
    You're a towel.
    Facebook me here
    Jul 2012
    Utah
    Re: Up pipe, 3 point boost control?
    It's an 04 wrx. I was looking into the 3 point controllers because I thought it would be nice to get full psi around 4000 to 4500 rpms and hold till red line. And when I go stage two, it'll come in hand. My tuner sold me on one....
    Mt. Laurel, NJ
    You're a towel.
    So would it benefit a VF39 as well?
    zax
    zax is online now
    Nov 2008
    Definitely. Buy a 3-port and I'll help tune.
    Facebook me here
    Moderator Donkey's Avatar
    Da boonies
    Quote Originally Posted by skinikko View Post
    I get 20psi by about 2800-3000 rpm in 3rd gear. You will never hold peak boost to redline on the stock turbo
    Sent from my magic banana
    2002 FORESTER S
    1998 FORESTER S
    zax
    zax is online now
    Nov 2008
    Huh for some reason I missed that post... but yeah the stock TD04-13T frankly does not move enough air to hold 18 PSI at redline
    Facebook me here
    Unless you have the ability to modify the tune yourself, I wouldn't bother with an EBCS on a car that doesn't have a downpipe.
    Ahem! Have you read the second line in his signature, dear?
    May 2010
    Pittsburgh, PA
    You should never hold peak boost to redline on the stock turbo
    Fixed!
    2011 STi Build Log
    2.0L snail power... Rambo's Avatar
    Oct 2010
    Korea/Japan/Taiwan/USA
    You should never hold peak boost to redline on any turbo
    Further fixored.
    Isaac -- 2003 WRX sedan Stg II
    He who shall be last, shall be sideways and smiling... - Jeremy Clarkson
    May 2010
    Pittsburgh, PA
    Quote Originally Posted by Rambo View Post
    Further fixored.
    I disagree actually. It depends on what you are aiming for. If I was making a time attack car... I'd size my turbo to hit peak boost within a few thousand rpm of redline... and hold it until redline. Pending reliability concerns and the such. It all depends on the situation.
    Look at most GT35r builds for example. If you can supply the CFMs at redline efficiently... may as well if the engine can take it.
    2011 STi Build Log
