Up pipe, 3 point boost control? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
This is a discussion on Up pipe, 3 point boost control? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I ran my 16G-XT 22 psi to redline no problem on 93 octane. Same with my 18G. Sent from my ...
    Moderator Donkey's Avatar
    Da boonies,Va
    Sent from my magic banana
    2002 FORESTER S
    1998 FORESTER S
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    I ran my redline to 35 PSI.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Da boonies,Va
    I ran my blueline to 3500ft
    2002 FORESTER S
    1998 FORESTER S
  6. #19
    Palmyra, NJ
    Definitely. Buy a 3-port and I'll help tune.
    Goddamnit Mod bug itching again....
  7. #20
            MainFrame's Avatar
    Austin, TX
    I disagree
    +1
    I'm not planning on tapering boost on my 93 octane map. My plan for 93 is pretty conservative timing and 21-23 psi to 7500rpm. .might not really taper my e85 map either since I'm having to limit boost to 27psi. I'll just have to see how the VE works out with the updated heads. If I can stay in a decent efficiency range to 8500rpm at that pressure ratio, why not? Right?
  8. #21
    zax
    zax is offline
    Nov 2008
    You road the blue line for 3500 feet? Pentagon City to Crystal City?
    Metro - Rail - Maps - Rail/Google Map
    Facebook me here
  9. #22
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    If I was making a time attack car... I'd size my turbo to hit peak boost within a few thousand rpm of redline... and hold it until redline. Pending reliability concerns and the such. It all depends on the situation.
    Well ok, fair enough, but it doesn't sound like the OP is building a time attack car, which was my point. Sure, if you've got a built engine, and are driving the car in a style that needs high rpms, go for it. Time attack and AutoX come to mind, but I still argue it wouldn't be useful for a daily driven car in normal traffic.
    2007 Outback 3.0R wagon
  10. #23
            MainFrame's Avatar
    Austin, TX
    And I ran my brown line to the bathroom. .
  11. #24
    May 2010
    Pittsburgh, PA
    +1
    True, but I/we do see Rambo's point, which should be stressed for others for reference.
    With most smaller turbos, it is worth opening the wastegate to lower boost pressure towards higher CFMs (redline)... even if its possible to hold pressure. At that very high engine speeds (for a smaller turbo, again):
    -The turbo is out of its efficiency range. You may get more mass into the cylinder with denser, colder air at a lower drive pressure by opening the waste gate. The intercooler plays a large part in this, obviously.
    -The turbo just can't put out enough CFM to supply the engine while the valves are open for such a short period of time. A good analogy would be why adding a fuel pump can reduce injector duty cycles (IDCs) in the higher IDC range, or why people upgrade fuel rails to a certain extent... Fluid dynamics.
    2011 STi Build Log
  12. #25
            MainFrame's Avatar
    Austin, TX
    Right. .you will need to consult compressor maps, tuner experience, as well as how the car actually responds during the tune to determine what pressure ratio to run on order the achieve the best/safest results. On a td0d this certainly doesn't mean trying to push 18psi at 7000rpm, that turbo is just a little guy.
  13. #26
    Palmyra, NJ
    The brown line ran down your leg?
