Results 1 to 5 of 5
This is a discussion on Is there ANY way on God's earth that's easier to get the turbo vac line on??????????? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I've been at this POS for I don't know how long... the wastegate is in the way, everything is in ...
    Jan 2009
    Md
    I've been at this POS for I don't know how long... the wastegate is in the way, everything is in the damn way... i'm ready to sledgehammer this car!!!!
    2012 WRX: TurboXS DP, AEM CAI, TP stage 2 tune
    Jan 2009
    Md
    and even if you get it on there, how in the hell would you be able to zip tie it????
    Registered User starkall's Avatar
    Sep 2010
    Start the zip tie on the line first, tighten zip tie with extended needle nose
    Registered User Eric05mx's Avatar
    Oct 2010
    PA
    For installing a 3 port ebcs? I installed mine in the parking lot before getting a tune. It wasn't too bad thanks to a few Snap-On goodies.
    2012 WRX ice silver metallic
    Protuned by Agile Auto 315whp/342wtq @ 20.5psi
    Jan 2009
    Md
    Quote Originally Posted by Eric05mx View Post
    I had one HELL of a time getting that one tube on from the turbo... the WG wasn't that bad though. I've got TP's stage 3 map, so i'm just waiting for it to warm up maybe a little bit so Eric can tweak the map.
