Running rich???
Results 1 to 15 of 16
This is a discussion on Running rich??? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; ok so just recently my wrx has been running rich. i dont understand why it would. on my 09 i ...
    Aug 2009
    Beaufort, South Carolina
    Running rich???
    ok so just recently my wrx has been running rich. i dont understand why it would. on my 09 i have a spt catback, walbro 255 fuel pump, and avo top mount intercooler. after installing the intercooler i started backfiring. i have not done the tune yet but i will once i install my invidia cattless divorced downpipe. just wondering if it should be running that rich. i do run 93 octane. if you have any info about this please let me know.
    Oct 2011
    Santa Ana, CA
    I just tuned my car to run a rich....er. 10.53 AFR.
    Enough of me being an ass...
    Turbo cars are supposed to run rich. What makes you mention this now?
            MainFrame's Avatar
    Austin, TX
    How rich is it running.. idle and WOT?
    Registered User EndlessSea's Avatar
    Nov 2012
    Las Vegas
    Quote Originally Posted by yongsik_park View Post
    Umm.....
    Am I the only one who read this
    You have an aftermarket fuel pump and intercooler on the stock tune
    And your asking why it's not running right? Seriously?
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by EndlessSea View Post
    Umm.....
    Fuel pump should make no difference, and intercooler doesn't nesicarilly need to be tuned for.
    Aug 2009
    well i know that turbo vehicles run rich but its shoots back smoke out of the exhaust. and every once in awhile the car would shut off and i would lose power steering.
            MainFrame's Avatar
    Austin, TX
    I would suspect you have a different problem going on if the car randomly dies. No way to really tell if you're rich or lean without at the very least reading from the front O2 sensor. You would really need a wide band installed to know what your mixture is like.
    How's your fuel economy?
    Aug 2009
    i was told that i dont need a tune too. it just doesnt seem normal to backfire with all my cats.
            MainFrame's Avatar
    Austin, TX
    Something is not functioning properly.. I would check the readings from your front O2 sensor, it may have failed.
    Aug 2009
    pretty bad to be honest.
    Aug 2009
    kinda figured. i guess i will just wait till i get my car tuned. then see whats happening
    Registered User anpato's Avatar
    Jun 2012
    I backfire with my cats, although i also have no mufflers, and my car is bone stock. I usually backfire after a launch and 1-4 WOT pulls.
    2013 SWP WRX Sedan
    Hillside, NJ
    Invidia Catless Downpipe, Custom Short Ram Intake, Self Tuned Using ECU Flash, Romraider and Tactrix
    Aug 2009
    when i first got my 09 i never backfired once. lol.
    Apr 2007
    8000' up in Colorado
    Why do you have the Walbro fuel pump instead of just the original one? Why did you go with the aftermarket IC too i.e. what exactly were you trying to accomplish by replacing your OEM one? Are you the original owner of the car? If not, when did you buy it, and do you know the modding history of it?
    What tune are you going to run once you put on the invidia DP?
    To answer you specific question, no it's not normal that your car is running very rich after just changing the IC. But what are you basing your statement on that you're running very rich? Just on the fact it's backfiring? You really need to get a datalog to get good data rather than just basing things on some backfiring. How often is it doing it, and under what conditions? Does it only happen very occasionally, and only when you let off from a WOT pull in 2nd, 3rd and/or 4th gear? Or does it happen a lot like every time you drive it and many times during each drive, and also when you're not doing a WOT pull but just driving normally?
    Scott
    Moderator Donkey's Avatar
    Da boonies,Va
    Basically this. Could be you have a boost leak. Don't know. You have not really provided any substantial data. At this point it is anyone's guess. Especially since we can't even see the car. But seeing how all this started once you put on the intercooler I would lean towards an improper installation possibly.
    2002 FORESTER S
    1998 FORESTER S
