Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
This is a discussion on AFR gauge w/ WB o2 Sensor within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Yeah AEM is what I got...
    Turtles and Penquins 11blackSTi's Avatar
    Nov 2012
    MAINEiac
  2. #17
    2.0L snail power... Rambo's Avatar
    Oct 2010
    Korea/Japan/Taiwan/USA
    It comes with a 0-5v analog output that supposedly works with data loggers and "virtually any engine management system."
    Right, but the Cobb AP doesn't have an analog input port on the device, unlike the Tactrix OP2.0, which does. It sort of defeats one of the key advantages of the AP (easy standalone logging) when you still have to drag out your laptop to just log the wideband data.
    Isaac -- 2003 WRX sedan Stg II
    He who shall be last, shall be sideways and smiling... - Jeremy Clarkson
  3. #18
    zax
    zax is offline
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Re: AFR gauge w/ WB o2 Sensor
    Quote Originally Posted by Rambo View Post
    I have to do that with the UEGO anyhow.
    Beamed at your face at approx. 186,000 miles per second via DROID BIONIC
    Facebook me here
  4. #19
    zax
    zax is offline
    Nov 2008
    I was wondering how that works.. I'm assuming you still have to buy a serial->USB cable, how do you connect the WBO2 logging cable to the AP? It was simple enough with my laptop and RR, but I've always wondered what you do if you're on the Cobb train.
    You use the serial port. In my case I used a USB-Serial adaptor to the computer, and the Cobb adaptor to the ECU. Logging is done in ATR.
    Facebook me here
  5. #20
    Texas, United States
    Ahhhhh.. well, that kind of sucks. Might as well use RR if you're having to tote a laptop.
  6. #21
    Nov 2012
    MAINEiac
    Anyone use an iPad for their datalogging? Just curious if the software would even work on a iPad. That would be much more convenient than having a laptop out!
  7. #22
    zax
    zax is offline
    Nov 2008
    Well I agree, which is why I switched to OS
    I have a dedicated tuning laptop that I leave in my car. It's a POS from 2002, so the person who attempts to steal it will be very disappointed at its value
    Facebook me here
  8. #23
    Moderator Donkey's Avatar
    Da boonies
    I run Dash Commander off my Iphone with a PLX KIWI2. It has the ability to log a wideband as well. But both Innovate Motorsports and PLX have wireless/bluetooth options. Not sure about AEM.
    Innovate Motorsports OT-2 - Transform your iPhone or iPod into a wireless gauge, data logger, dyno, efficiency meter and OBDII scan tool.
    Kiwi 2 iMFD Adapter | OBD iPhone
    2002 FORESTER S
    1998 FORESTER S
  9. #24
    Oct 2010
    I was under the impression you could use the AUX channel on the OP2.0 to monitor the UEGO's analog output with an 1/8-in. phono cable? Is that only for Innovate devices? If so, damn.
  10. #25
    zax
    zax is offline
    Nov 2008
    Not sure, I haven't seen anything like this for AEM :-/
    There may be ways to do this, but it does not work out-of-the-box with the OP2.0.
    Facebook me here
  11. #26
    Oct 2010
  12. #27
    zax
    zax is offline
    Nov 2008
    In theory, the 1/8" phono cable carries a digital signal that is interpreted by the OP2.0 hardware. The AEM does offer two outputs -- a digital signal that is used to broadcast over the serial port, and an analogue output that is presumably used to interface with standalone EM systems. It shouldn't be too hard to interface with the OP2.0, but the Innovate uses some configuration file we'd have to crack and use with the AEM.
    Facebook me here
