i have mine set to 5k right now, i plan on moving it up a little more to get it better adjusted. when you are 100% throttle it sets a rev limiter to keep the rpms up and the turbo spooled. so you just keep it floored and then hit the clutch and shift very fast, you only have about a second or 2 before it will shoot up and hit the limiter. as stated mine is set to 5k and i shift around 6000-6200
LinkBack URL
About LinkBacks
