Results 1 to 7 of 7
This is a discussion on Darton Sleeves has anyone ?? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I ask as I have been looking at my options for building a solid bottom end. My 2002 WRX has ...
    Jan 2013
    Calgary
    I ask as I have been looking at my options for building a solid bottom end. My 2002 WRX has 200K on it so thought it best to either build up a new bottom end
    or maybe strip my down and rebuild it....
    Option 1 is buy new Block (Larger 2.5 Bore) a 75mm Sti crank after market rods and pistons....
    Option 2 Still buy the Sti crank aftermarket rods pistons but sleeve my 02 block with Darton sleeves.....
    Can you machine out a EJ20 block out to 98mm with these sleeves ???
    I would want to keep the revs so don't want to stroke the crank any more..
    Any help would be great as I'm very new to these motors ( owned more than a few V8's in the past )
    Texas, United States
    How much power are you trying to make? And how much boost to you plan on running to get it there? Sleeves usually aren't the answer, especially for a street car.
    Moderator Donkey's Avatar
    Da boonies
    I would try to get a hold of an EJ207 block before sleeving. It's just not a cost effective option nor generally one that is first choice for a build. Especially just a DD/street car. I would just have the stock crank cleaned,polished and cyro treated. Toss in a set of forged rods and pistons,have everything balanced,slap on a 2.5L oil pan with re-enforced pickup tube,port the heads and call it a day.
    2002 FORESTER S
    1998 FORESTER S
    Jan 2013
    Calgary
    What block do I have ?? A EJ 205 ?? Is the 207 stronger
    Sorry for the newby question
    Jan 2013
    Calgary
    As fat as my BHP target I'm not sure just a fun 300 + I suppose I don't want to go big
    And make it to serious . Just want to spend some money on a stout bottom end..
    For anything under 600whp (800bhp+) running under 28psi boost pressure sleeves would make it LESS reliable. Even up to 600whp, as long as people are running ~27psi or less (without ridiculous timing) they very rarely have any issues with the stock sleeves. Any cracked sleeves I have seen from people running less than 30psi were the result of bad tuning. A lot of people who get Darton sleeves installed end up with the sleeves coming loose/dropping, so it's not worth it.
    For 300bhp, I would say a stock block will be the most reliable. No one can build a Subaru motor as good as Subaru. If you're wanting 330whp+ I would get forged pistons. If you go with a STi block, the stock STi rods are easily capable of handling 400whp, although there are lighter options that will be just as strong.
    Jan 2013
    Calgary
    Thanks again for the advice..... I need to be sensible about this car but the Kid in me always wants more....
    I think the adult in me may win out this time though....
