Page 3 of 3 FirstFirst 123
Results 31 to 31 of 31
This is a discussion on help whats better AEM INTAKE OR STOCK AIR FILTER? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Technical Articles Comparing other cars to Subaru's is pointless if for one you don't understand the difference between MAF based ...
  1. #31
    Moderator Donkey's Avatar
    Da boonies
    Technical Articles
    Comparing other cars to Subaru's is pointless if for one you don't understand the difference between MAF based fueling and MAP based/speed density fueling and secondly the difference between MAF sensors and what the issue is. The main issue is that the GM/FORD type is housed in it's own enclosure. So for the most part it's calibration stays true. All your doing for the most part is shoving a filter on the end. The newer Subaru MAF as used in all the USDM WRX/STI's has to be calibrated to the ID to whatever housing it is installed in (new intake tube).
    GM/FORD type MAF:
    Suabru/Toyota type MAF:
    2002 FORESTER S
    1998 FORESTER S
