The fact that the car they used had the other MOD's already make me leary! You cant claim gains on a MODed car you just cant! I want to see the results on a bone stock WRX with clear indications of the AF ratio! There claims that it can be used in the stock ECU means nothing until i see clear proof and test results and even then anybody can post pictures of false tests online.. Buy the way im not being mean to you or cocky at all because as ive admitted before im not an expert with Turbo cars but i do now enough basic info and i know i some things can come across on forums when you type and cant hear the tone of the other persons voice. Im just saying that i want the best for my car and before i would add any MOD's i need to see plenty of proof and research that its safe. To me if the stock can handle 400hp why would you need to spend $300 on a new filter system! I would be more ap to use a performance air drop in filter like AEM then the entire CIA.. I think that would be good enough and safer! But that said i still would do research on that to make sure that the new filter would filter out dirt and dust as well or better then the stock filter before i would use it!
LinkBack URL
About LinkBacks
And they did use it on a car that had other modifications. However, they do state right on the compatabilty tab that this is designed to work with the stock ECU settings. If you have other modifications they say you do need a tune. I know basically nothing about tuning, but I would assume that is because you have already had your car tuned and the tune didn't assume a higher flow intake?
