As a general rule you likely won't see much power difference between the two on a dyno. Nothing that can't be attributed to dyno error, at least.
This is a discussion on looking for real dyno numbers with Perrin vs. PW TMIC. within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I was looking into one of these 2 going up to stage 3 along with a fuel pump, a 3 ...
I was looking into one of these 2 going up to stage 3 along with a fuel pump, a 3 port and the TMIC. I know that the PW is an excellent IC an excellent quality and the fitment is excellent. However, to spend an additional 2-300.00 for very few hp ... or even worse, none at all... I wanted to get possibly some real numbers to help me with my decision.
2012 WRX: TurboXS DP, AEM CAI, TP stage 2 tune
beyond power do the PW and Perrin cool the car the same?
2011 Subaru WRX Premium
1988 Ford Mustang GT
2000 Jeep Wrangler TJ
Subscribed to see what people have to say about this because I have wondered about this myself. I would like to go stage 3 at some point and had the same question about if the PW TMIC is worth the extra few hundred dollars.
-Noah
2009 Spark Silver Metallic Sedan - Stage 2+
Build Thread: http://www.clubwrx.net/forums/builds...wrx-sedan.html
Oh I definitely think that it's worth it. The quality is outstanding. It comes with the shroud, and the tubing which is super strong from what everyone has said, so there would be no collapse under heavy boost.
However, Perrin is certainly no slouch by any means and also make very nice products. I had one of their BOV's for my old Evo and it was a very good, quality piece.
I am only planning on buying one and only one time so I just want to make the best decision. Perrin has a dyno on their chart, but it doesn't show great numbers and I know that more power can be had from what they are showing... but maybe I am misreading the charts which is why I wanted to ask around here to see what kind of power I might see from both from stage 2 to 3. Especially when a 3 port and extra fuel can be added.
Yep, the two things you're looking at with an intercooler are efficiency and pressure drop.
Of course dyno comparisons are completely irrelevant with intercoolers because the dyno does a very poor job of simulating real world air flow conditions. That is unless you only drive the car on a dyno and never on the street, which isn't totally unheard of..
im planning on saving for the PW TMIC but if i can save some money and still have a good TMIC i wouldnt mind the savings
Yeah their dyno charts are only with their stage 2 tune and not anything to specifically account for the new intercooler. Did you by any chance ask Eric at TP? I see that you're already running a TP tune and I assume you would be going with his stage 3 tune. Maybe he has some dyno or road dyno numbers he could give you. Keep me posted.
-Noah
Again, you're not going to see much/any of a difference that can't be attributed to dyno error. They probably have similar pressure drops and somewhat comparable cooling ability. I would expect similar tunes with most decent TMICs.
Personally, I would go with PW or ETS (when they release an '08+ WRX I/C). If your tuner recommends a certain product, you should go that route; since the tune is the most important aspect of your build, you should go by what they want on your car.
-Noah
700 for perrin vs 900 for PW is a big jump and if they perform similarly the extra 200 like noah said could provide the ebcs and tune
The IC is a really critical piece of a highly modified, high output turbo system versus a stock turbo system where the relative differences in performance between different ICs are much less important. However, I've never seen any detailed dyno info about the Perrin versus the PW units, so all you're going to get (unless there's something out there I'm unaware of) is people's personal opinions.
Here's a LINK to the most detailed comparison of the two I've seen. It also includes a comparison with the stock STI TMIC, which should be another option you consider. Those typically go for $300-350 so they will save you significant money over either of the two aftermarket options.
Scott
Oh I would LOVE to get an ETS. I had a 4" FMIC on my Evo X and quality was EXCELLENT. I don't know how long it will be before it comes out though. I do know Michael said they would be working on one when they got back from some convention or something ETS was at. I don't recall now.
