Need help with stage 2 tune. - Page 4
Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 63
This is a discussion on Need help with stage 2 tune. within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by EJ257 Without seeing the map, and only going by the log, I would disagree that the car ...
  1. #46
    Registered User SubiEj255's Avatar
    Jul 2012
    Baltimore
    Without seeing the map, and only going by the log, I would disagree that the car was "running fine".
    You're overboosting with the LWG map. I would say try flashing the Cobb OTS S2 91 map (continue to fill with 93) and see how that looks.
    Do you E-tune? Would you like to see the map?
    Here is the 91 oct tune with 93 oct in the tank
    https://docs.google.com/spreadsheet/...2pUSTVDRlIxTlE
    A car is only as good as its driver
  3. #47
    Registered User PartyPizza's Avatar
    Jun 2011
    You're over boosting significantly at high rpm. According to Cobb, you want TD Boost Error to be a small, positive number.
    I'd run the 91ACN LWG map until you can protune for the catless DP. It's nearly identical to the 91 map, but has lower boost targets/waste gate duty cycles.
  4. #48
    Jul 2012
    Baltimore
    It seems when the target boost are lower, I over boost. I will pull a log. However the etune is what I was currently running. I really don't need the Cobb maps, I'm just trying to figure out what a log should or "ideally" look like.
  6. #49
    May 2010
    Pittsburgh, PA
    Re: Need help with stage 2 tune.
    Quote Originally Posted by PartyPizza View Post
    Is the OP running a cat less down pipe? I didn't see it mentioned. It would make sense.
    The flip side, even with a pro tune, if it is due to the cat less dp, it won't be resolved most likely.
    2011 STi Build Log
  7. #50
    Jul 2012
    Baltimore
    Yes, I am running catless
  8. #51
    May 2010
    Pittsburgh, PA
    Quote Originally Posted by SubiEj255 View Post
    Again, haven't looked at your logs, but if primary wgdc is zero (after corrections) and you are over boosting still... That isn't gonna be resolved with a pro tune. Even if you aren't boost creeping, I bet you'll have boost control issues until you get a different waste gate (turbo with iwg or ewg).
    To test for this, run your manifold pressure directly to the wastegate nipple. This will be mechanically setting your wgdc to zero. Do a WOT pull. See if your boost is higher than spring tension (7ish psi). Plug the other open part of the line with something tightly. I used a screw and a tight wire tie. Be careful here... You can just as easily run 100 wgdc by leaving the wastegate isolated from the manifold (eg open boost line causing wastegate to not see manifold pressure)
    2011 STi Build Log
  9. #52
    Jul 2012
    Baltimore
    It's not like extreme over boost tho.
  10. #53
    May 2010
    Pittsburgh, PA
    Doesn't have to be
    2011 STi Build Log
  11. #54
            MainFrame's Avatar
    Austin, TX
    Doesn't have to be
    Exactly.. 1psi over target can be the difference between running 200k miles, and a blown engine (if it pushes it into a load range that isn't tuned for).
  12. #55
    Jul 2012
    Baltimore
    Does anyone here etune?
  13. #56
            MainFrame's Avatar
    Austin, TX
    A few poeple.. Ron and Matt.
  14. #57
    Jul 2012
    Baltimore
    I dont know them by name
    How does this map/log look?
    https://docs.google.com/spreadsheet/...lZUWThZeHZ2NHc
  15. #58
    May 2010
    Pittsburgh, PA
    Not to mention it is difficult to modulate boost throughout the band. You'll hit unexpected and difficult to control boost spikes. A good exercise, if you hate your life, is to try to get a 3 port ebcs tuned to have near mechanical spool on a system with boost creep. Until I got my EWG, I always had to open the solenoid pretty early relative to peak boost in order to prevent the nasty boost spike that would occur otherwise.
    2011 STi Build Log
  16. #59
    May 2010
    Pittsburgh, PA
    I'm not familiar with Cobb's "dynamic advance" tables. I saw your DAM was 1 which is a good thing (it should be 1, otherwise you have some fairly substantial issues). I also did not see any FLKC or FBKC.
    Boost wise, here is your graph:
    You didn't log anything that would show if that was what the tune is aiming for or not. Next time Take out MAF(g/s), IDC, AFRs (the stock sensor is useless under boost anyhow), AFC, & AFL (when doing a WOT pull). That will give you better resolution for other things you need. That's a fairly aggressive tune in my opinion, especially without knowing your actual AFRs.
    Things that would help:
    -Target Boost (or you can dig through the map notes. I would rather log it to see it post compensations & DBW stuff)
    -WGDC (to see if you are boost creepin' or not)
    -Possibly WGDC corrections in the future
    Also, what else is done to the car other than a catless downpipe? It would be useful to know now. Intake? EBCS? Just group them up in a conclusive place for us. My apologies if they are buried somewhere else that I missed.
    2011 STi Build Log
  17. #60
    You keep switching maps, and posting logs. For every log you post, you need to tell us what the map is so we have an idea of what's going on.
    You need to make sure boost is close to target, and you need to make sure the knock parameters are in line. Remove the parameters that Brandon mentioned (as well as MAFv and the two Dynamic Adv ones, leave DAM) to get better resolution. Add in TD Boost Error.
    Cobb S2 maps target like 17-17.5, I believe. You're overshooting that a good bit, if it's one of them.
    Resident Tuner @ WTF Tuning
