Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 63
This is a discussion on Need help with stage 2 tune. within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Was that post supposed to be blank?...
  1. #31
    Registered User SubiEj255's Avatar
    Jul 2012
    Baltimore
    A car is only as good as its driver
  2. #32
    Jul 2012
    Baltimore
  3. #33
    Quote Originally Posted by SubiEj255
    Neither one is good. That said, the first one is "better" because you aren't pulling timing across the board by having a DAM of 0.
    You're pulling quite a bit of timing on both. You need to consider that you either have a mechanical issue, or the car is not taking that map well.
  4. #34
    Jul 2012
    Baltimore
    I figured that. What I don't know is the numbers I'm "supposed" to look for? I simply don't understand some of the values what they mean and where they are supposed to be. For example the "DAM" I understand quite well I think, but the FBKC and FKL I don't understand what they indicate.
  5. #35
    Jul 2012
    Baltimore
    Mechanical issue? The car only has 20xx miles on it; unless it is a part that I installed wrong..
  6. #36
    You don't want your car to be pulling timing, which is indicated by either FBKC, FLKC, or DAM.
    RomRaider • View topic - Subaru's knock control strategy explained
  7. #37
    Jul 2012
    Baltimore
    So the values in FBKC or FKL are supposed to stay at 0? When they aren't at 0 the car is removing timing to prevent knock. Did I get that correct?
    What does the "DAM" and "Dynamic adv" indicate?
  8. #38
    May 2010
    Pittsburgh, PA
    Re: Need help with stage 2 tune.
    Quote Originally Posted by SubiEj255 View Post
    I'd vote user error. It's not hard to make an install mistake.
    In a nutshell:
    Occasional Fbkc = Meh. Short term issue. Stuff happens.
    Flkc = stuff needs fixed
    Dam/iam at zero = stuff needs fixed now
    2011 STi Build Log
  9. #39
    Yes. FBKC should always be 0 (ideally). FLKC should always be 0 (ideally), but will be negative if you pull timing, and will only be positive if IAM/DAM<1 and it's "testing the waters" in an attempt to raise the IAM/DAM back up.
    DAM: Dynamic Advance Multiplier (IAM, in the link I sent you)
    Dyn Adv: The amount of timing being added to the base timing table
    Ignition Timing = Base Timing + DAM*DA + FBKC + FLKC + Compensations (IAT, ECT, etc.)
    As a general rule, it's pointless to log either Base Timing or Dynamic Advance; essentially, they're just wasting bandwidth, which is already limited with Cobb logs.
    Quote Originally Posted by Heide264
    Depends what you mean by "occasional"...
    If you get repeated FBKC in a similar RPM/Load range (but not every time), you're too close to the knock threshold, and need to address it. If RPM/Load FBKC can't really be replicated, it's not that big of a deal, assuming it's the first iteration (there's a table that explains what the FBKC retard value is).
  10. #40
    May 2010
    Pittsburgh, PA
    First paragraph, yes.
    Second paragraph.. I am not sure about Cobbs DA. I just know DAM infers there was enough fine learning (flkc) that the car decided it's time to pull timing across the board with rough correction (dam in cobb/iam in open source)
    2011 STi Build Log
  11. #41
    Jul 2012
    Baltimore
    ok, I am learning slowly, but surely and I definately appreicate the help.
    How about this log?
    https://docs.google.com/spreadsheet/...nQxSHRuV25ZeVE
  12. #42
    How about this log?
    That's a lot better. What map are you running?
    I don't like the >100 IDC, but it's not knocking.
  13. #43
    Jul 2012
    Baltimore
    Ok, see I thought so. Is overboosting an issue in that log?
    Here are the maps as follows: the very first log was an e-tune map that the tuner said the car was running fine. So I paid for that. The second log was a standard Cobb OTS stage 2 93oct map and the last and an OTS stage 2 93oct LWG Cobb map.
    Overall, minus the idc's the log is "ideally" supposed to look like the last log I posted right?
  14. #44
    Without seeing the map, and only going by the log, I would disagree that the car was "running fine".
    You're overboosting with the LWG map. I would say try flashing the Cobb OTS S2 91 map (continue to fill with 93) and see how that looks.
  15. #45
    May 2010
    Pittsburgh, PA
    I am surprised he is at 100idc. The wrx and sti run the same injectors, correct? If so, I am still under 100 idc.
    2011 STi Build Log
