Need help with stage 2 tune. - Page 2
Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 63
This is a discussion on Need help with stage 2 tune. within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by SubiEj255 My concern isn't the boost, it's the knock. You clearly are not understanding the relationship between ...
    Moderator Donkey's Avatar
    Da boonies,Va
    Quote Originally Posted by SubiEj255 View Post
    You clearly are not understanding the relationship between the two. I don't know how to make it anymore clearer than what has been already stated several times.
    2002 FORESTER S
    1998 FORESTER S
    I do know that. I put a different map on. It seems to be running better. I haven't seen the log yet.
    Check your DAM before doing anything WOT.
    Resident Tuner @ WTF Tuning
    Registered User SubiEj255's Avatar
    Jul 2012
    Baltimore
    During regular driving or idle?
    A car is only as good as its driver
  6. #19
    Jul 2012
    Baltimore
    Also, who can I get an etune from? Could someone send me a map and I use the Cobb to re flash it or do I need the tactrix?
  7. #20
    Jul 2012
    Baltimore
    Probably because the map was designed for catted downpipes only.
    Look at the boost error. Where you're hitting 19.61psi at 4999rpm, your tune is targeting 16.3psi. Doesn't look so much like creep, just over boosting.. so hopefully the LWG map will do you right.
    https://docs.google.com/spreadsheet/...nQxSHRuV25ZeVE
    This looks a lot better, but the IDC's are kind of high. What would happen if I were to retard the timing a degree?
  8. #21
    Registered User PartyPizza's Avatar
    Jun 2011
    Still over boosting. May want to run the 91 or ACN map.
  9. #22
    Jul 2012
    Baltimore
    Quote Originally Posted by PartyPizza View Post
    The 91 looks almost identical. Peak boost was 18.8 or something. I will post that log pretty soon.
  10. #23
    Mar 2012
    Pasadena, MD
    You need to either get a protune or switch to a catted DP, these maps were not designed to be ran with a catless downpipe. You're going to end up doing major harm to your car if you keep driving it with the way it's running right now.
  11. #24
    Jun 2011
    According to Cobb, you want TD boost error to be a small, positive number throughout the range. The 91 map should have lower boost targets, and the ACN map should have even lower wastegate duty cycles.
    Running lower boost should bring down your IDCs as well.
    And yes, they were designed for a catted downpipe. I'd only run catless with a protune, but to each his own.
  12. #25
    Registered User frenziedcage's Avatar
    May 2012
    Colorado
    Yes.. WOT = wide open throttle
  13. #26
    Jul 2012
    Baltimore
    Where did you see that? What classified as a "small positive" number? After looking at the logs I pulled from the stage 1 map. The TD boost appears to be a little better, but still goes into the negs
    I'm going to get a protune.
  14. #27
    Jun 2011
    https://static.cobbtuning.com/cobbtu...ile_Subaru.pdf
    Page 11. And I'd run the 91acn map until you get a protune.
  15. #28
    Mar 2012
    Pasadena, MD
    And baby the crap out of the car while you're at it or if it's going to be a while before you can get the protune I'd just throw the stock DP back on. I'd hate to see you blow up your car bud...
  16. #29
    Jul 2012
    Baltimore
    I read it. Thanks for the link. I will pull a log with that map to see how it looks. I read around and other guys are saying as long as my a/f ratios are fine and I'm not getting knock; my combustion chamber will be happy. I am over boosting slightly, but the map says +/- 1 psi. However I will pull a log and I appreciate the help.
  17. #30
            MainFrame's Avatar
    Austin, TX
