This is a discussion on Purge solenoid delete within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; hi guys i want to delete the purge solinoid by blocking it off i want to do it correctly because ...
hi guys i want to delete the purge solinoid by blocking it off i want to do it correctly because last time i broke the solinoid and car sputtered here and there idle was funny but i put a new one and fixed i do get cutting out when im cruising here and there my hode from the black round thing to the intake is cracked i want to remove the solinoid completely anyone can tell me wich holes to block up? oh and it throws cel i will disable it via rom raider
i found a diagram here Purge Control solenoid valve hooked up correctly? - NASIOC
