Results 1 to 3 of 3
This is a discussion on Stage 2 AFR Question within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I just tuned my 2011 wrx to stage 2 and I am concerned that it is running too lean at ...
    Registered User VT2011WRX's Avatar
    Jun 2011
    Burlington, VT
    I just tuned my 2011 wrx to stage 2 and I am concerned that it is running too lean at idle. I have noticed that when I put the clutch in and the engine is idling as I am rolling (at approx 2k rpm), the air fuel ratio is a constant 20.4. As the rpms drop to about 700 the AFR drops to around 14.5 but it pauses at 20.4 for a few seconds before dropping. Is this cause for concern having the AFR so lean? It seems to be ok at other areas from what I can tell. The mods that I have are Cobb SF intake, Invidia catted downpipe, and Nameless Performance muffler delete. I am running the stage 2+ low wastegate OTS map. I am noob when it comes to data logging and monitoring so sorry if this is a dumb question. Any input would be greatly appreciated.
    Moderator Donkey's Avatar
    Da boonies
    It's completely normal. The engine is not even under any load.
    Sent from my magic banana
    2002 FORESTER S
    1998 FORESTER S
    Jun 2011
    Burlington, VT
    Awesome, thanks!
