Results 1 to 15 of 28
This is a discussion on Intake and heat shield question within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Im planning on getting either an SPT or Cobb intake for my car soon. I'm not looking for any performance ...
    Dec 2012
    Im planning on getting either an SPT or Cobb intake for my car soon. I'm not looking for any performance gain, I just want the sound So my question is, should I just go with a turbo heat shield or would an intake shield be better?
    Apr 2007
    8000' up in Colorado
    What does the turbo heat shield have to do with the intake? There needs to be one on the car regardless of what intake or any other parts are being run.
    You also need to run an intake air shield with any intake to prevent it from being a hot air intake.
    You should look into the AEM intake instead of those two, though those two are the other two options on the market that are good. AEM makes the SPT intake fwiw.
    Scott
    Dec 2012
    I meant an aftermarket turbo shield like a cobb or spt. I was looking at those two just because I won't need a tune for them
    Registered User Soobvirgin's Avatar
    May 2012
    San Diego
    Tune for a turbo heat shield? Eh?
    I have the SPT heat shield. Not convinced it does anything.
    Dec 2012
    Quote Originally Posted by Soobvirgin View Post
    Ok, that was also kindo of confusing, I just ment with those two intake systems I wouldnt need a tune....not for the shield
    May 2012
    San Diego
    Quote Originally Posted by dragon wagon View Post
    Ohhh... gotcha
    Dec 2012
    Ohhh... gotcha
    I not taht nooob
    Jan 2012
    Philly Area
    What year is your car?
    - William
    Apr 2007
    A turbo heat shield is a critical part of maintaining optimal turbo performance. You won't notice it ever doing anything, nor will you notice any difference if you don't have one unless you ran extensive dyno tests. But they are absolutely necessary.
    Scott
    Dec 2012
    Its an 04 right now all stock minus a CBE which is why I was looking to stay away from getting a tune untill i can go UP, DP and an Accessport
    Texas, United States
    Not to mention it's vital safety equipment.. you would never know it's doing its job, until your car doesn't catch on fire.
    May 2012
    San Diego
    I wasn't saying that a turbo heat shield isn't necessary. But the SPT heat shield gets installed over the stock shield, it doesn't replace it. My point was that I'm not convinced adding the second shield has any benefit.
    Jan 2012
    Philly Area
    If you get an intake, you will need to tune for that.
    - William
    Apr 2007
    Are you sure about that? I believe it replaces the stock shield. If it does go over the stock heat shield, it will definitely have a significant benefit. It's like doubling the insulation on your house. It will not only keep more heat in the turbo, but prevent that much more heat soak into the intercooler.
    Scott
    Gold Member lokey's Avatar
    Jan 2011
    Crofton, MD
    This is much better than any heat shield. - PTP Turbo Blankets
    Even better, use this in conjunction with a heat shield.
    As for the intake, I'd go with the Cobb SRI (w/ the air box of course).
    Greg
    www.modmeets.com
    ProTuned Stage 3 '11 WRX Ltd HB (SWP) ~ 342 awhp 399 ft-lb tq on E85
    Mods Blog Post
    Friends don't let friends drive Mitsubishis.
