Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
This is a discussion on ewg? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; ^^ Not in the slightest. Took longer to get the OEM set-up out. Had to break off a piece to ...
    Aug 2010
    ewg?
    ^^ Not in the slightest. Took longer to get the OEM set-up out. Had to break off a piece to get to out, as per directions. Perrin slid right in. Believe what you will it was cake.
  2. #17
    Registered User Chance1218's Avatar
    Mar 2012
    Washington
    Go with a set of EL headers.
    yuck lol
  3. #18
    Aug 2010
    ewg?
    ^^ Agreed. I no longer sounds like a Subaru with EL...
  4. #19
    Oct 2011
    Santa Ana, CA
    Quote Originally Posted by careercadaver View Post
    I've done it. I agree on tearing apart the OE one. The Perrin one looks like its easier to squeeze in than my Gimmick. Still not a worthwhile mod unless the OE one is ripped, IMO.
  5. #20
    Aug 2010
    ewg?
    I was replacing my turbo and it just seemed like an easy time to do it. A buddy of mine had an eBay one on his car and said the Perrin was a lot easier as it flexed a lot more. I'm not certain there was any gain from it as I pretty much threw everything on and got a tune immediately, so I'd have to take your word on that. I usually only suggest the mod when someone wants more turbo noise and is thinking BOV...lol
  6. #21
    Correct. It sounds more like a Porsche.
  7. #22
    Toboggan T0rque's Avatar
    Dec 2004
    Your Mommas
    ewg?
    Grimmspeed has a ****ty coating on it so don't ever spend any money on them coating anything for you
    Lead Wrench @ WTF Tuning, LLC
  8. #23
    Texas, United States
    IMO, ELH sounds much better. The "Subaru" sound is the sound of poor design and inefficiency. Porsche had it right to begin with.
  9. #24
    Quote Originally Posted by MainFrame
  10. #25
    May 2010
    Pittsburgh, PA
    If you have boost creep (due to a catless down pipe, most likely), the EWG isn't much of a choice. Given that it costs more than the down pipe, it should be a consideration when choosing the down pipe. If you don't have a down pipe yet, I'd recommend one with a flat flange over a bellmouth if you are going EWG. You won't be utilizing the bellmouth portion much with the IWG blocked off... but that bellmouth does make it a biatch to torque down some of those bolts with the EWG in place.
    It'll give you much faster boost control at least.
    It comes down to what you want to do.
    2011 STi Build Log
