If they don't do a visual or a sniffer, and just plug in, then you'll be fine. The accessport, I am 90% sure, gives you the ability to eliminate CELs that would cause you to fail.
Well, the main thing is that you can run into issues with boost creep, which is potentially quite bad for your engine.what if i just flash it with a map thats for a highflow cat. could it hurt. i dont see it affecting much.
LinkBack URL
About LinkBacks
