Results 1 to 8 of 8
This is a discussion on Downpipe question!!! For 2012 WRX hatch within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hi all, So Im thinking about ordering the Tsudo Catless down pipe from ebay... It says it comes with all ...
    Sep 2012
    CT
    Hi all,
    So Im thinking about ordering the Tsudo Catless down pipe from ebay... It says it comes with all the correct gaskets and installation materials... I have stock exhaust, Aem intake, cobb AP, and a turbo xs bov... I am going to flash the stage 2 map from cobb.
    If I order this, I know ill need a new heat shield that will fit over the down pipe since the stock one is to small. Any you recommend?
    Has anyone done this dp onto the stock exhaust?
    Thanks!
    Alex
    here is the link to the dp. and i have a 2012 wrx hatch...
    Tsudo Subaru WRX STI 2008 2012 3" Catless Race Bellmouth Iron Flange Downpipe | eBay
    Cobb maps aren't compatible with catless downpipes
    Registered User elchino's Avatar
    Jul 2012
    You'll have to get a custom tune done. I have the DP now and have had zero issues. Took about 3 hrs to install in the driveway. Youll need the 3" to 2.5" adaptor to get a nice fit to the stock exhaust. Good Luck and enjoy!
    Sep 2012
    CT
    Quote Originally Posted by elchino View Post
    could i run the stage 2 map or avoid buying the adapter?
    thanks, and do you have a different heat shield?
    Quote Originally Posted by atissasha
    Like I stated before, Cobb maps require a catted downpipe. You can skip on the adapter, but you're likely to have an exhaust leak at the downpipe/catback joint.
    Three options (not accounting for turbo blankets):
    1) Modify your current one to fit the wider turbo/downpipe opening
    2) Buy an aftermarket one
    3) Don't run a heat shield
    Option 1 is your best choice, option 3 is the worst.
    Registered User mgmoehn's Avatar
    Jun 2012
    Peoria Area - IL
    Cobb fail
    2012 WRX Hatchback ISM - Base Model - STI STS, SPT Boost Gauge, AEM Intake, TP Stage 1 Tune, red illumination kit, cobb shift knob, 20% tint - currently on stock wheels wrapped in Pirelli Winter Carving Edge Tires
    Some cool tidbits to come...
    Registered User jlinnell98's Avatar
    Feb 2010
    Iowa
    Quote Originally Posted by atissasha View Post
    Hi all,
    Thanks!
    Alex
    CNT makes a reasonably priced catted downpipe. Also you could contact Eric at Torqued Performance, he told me his maps work with both catted and catless, I think he has maps for the AP (I did open source so I'm not 100%) so you could look into that if you are stuck on the eBay pipe.
    As far as the heat sheild, I cut the stock one and it worked just fine, took about 5 minutes. You should be able to find a DIY on here or with a quick google search. Also, if you go the CNT route, they offered to throw in the adapter with the downpipe, it's noramlly $29 I believe
    "If my calculations are correct, when this baby hits 88 miles per hour... you're gonna see some serious sh*t."
    '10 WRX DGM Sedan: CNT Catted DP, SPT Exhaust, Perrin STS adapter/bushings, TP Stage 2
    Registered User matsayz's Avatar
    Apr 2012
    Vegas
    Still learning but from what I've read over the months and what my local tuner did for me you could:
    Get the downpipe, toss the stock heat shield/buy a turbo wrap $100~ and finally get pro-tuned so you don't have to worry about cat dp vs catless dp. Best part about getting a personalized tune(pro-tune) is that it's exactly that, customized to your parts/car.
