Do you have a programmer such as an access port?
If so invidia
This is a discussion on Time for another Mod! within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; So for christmas I'm going to get myself a nice shiny downpipe! My questions are, what companies have a nice ...
So for christmas I'm going to get myself a nice shiny downpipe! My questions are, what companies have a nice throaty tone? I like it being very loud, doesn't bother me. Also, will I pass inspection with high-flow cat in NJ? I'm running Nameless Performance Axleback muffler delete's rite now and plan to continue running them, however if I will pass with a high-flow and the stock mufflers then I will obviously wrench for 15 minutes and put stock axleback on.
Any help and suggestions are greatly appreciated!!
***EDIT***
I will be using a COBB OTS stage 2 tune, until I go (probably sometime this summer, if i get more mods) for a protune.
If so invidia
Pretty much every downpipe is going to sound the same.. the differences will be catted or catless, obviously the later will be louder and more "open" sounding. I'm not sure if there is really a difference in tone between bellmouth or divorced.. there will be some difference I'm sure, but it shouldn't be much.
High-flow catalytic converter should not pass any stringent type of emissions testing, and it certainly shouldn't pass visual inspection. The question will be how strict the place you go to for inspection is at following federal and local regulations.
The axleback (muffler) will have no effect on emissions, only sound.
thank you for your knowledge, much appreciated.
So at this point, I'm thinking I'll go with a cat-less downpipe because I don't mind noise and I enjoy hearing all the noise the car can make, hell I'm still young and I mite as well enjoy it as much as I can while I still do! Only concern with taking the cat-less route is I've read about 'boost creep'? not to knowledgable on that but it doesn't sound like a good thing.
Also, what is the difference between bell-mouth and divorced?
Cobb maps require a catted unit. If you buy a catless unit and have mechanical difficulty, you cannot go to Cobb for support, since you can't follow instructions (well, you can, but they have every right to tell you to go pound sand).Originally Posted by Mike193
Bellmouth vs Divorced:
Exhaust FAQ
Looks like I'll be going with a high-flow cat, since I want it to be able to work with the stage 2 OTS cobb tune.
Are there any performance differences between cat-less and a high-flow cat?
EDIT:
also, as I look over the link you provided, I see that I have a 2nd cat beyond the downpipe, and also a resonator in the rear mid-pipe. For the stage 2 OTS tune do I just need to replace the front cat and leave the rear cat there? Also, will the stage 2 work incorrectly without a resonator.
ANOTHER EDIT: nvm i read more and am an idiot. it replaces both cats
So, I think I've decided, I'm going to go with the cobb SS 3" downpipe. Will this bolt right up to the stock mid-pipe?
Also, I mite just decide to order an aftermarket mid-pipe as well, can someone inform me on some pro's and con's for mid-pipes, or maybe even provide a link.
Cobb will bolt to the stock midpipe, or any midpipe that tapers to 2.5" to mate with the stock downpipe. If your plan is to go with an aftermarket midpipe, you're better off with a unit like the Invidia and using an adapter (Grimmspeed sells one) until you buy the midpipe.Originally Posted by Mike193
On the stock turbo, the 2.5" catback section isn't going to limit you all that much. I would do it, personally, so that you don't waste time/money with the adapter.
Or just go 3" from the startOriginally Posted by Mike193
Emissions in NJ is only a plug-in type to the OBDII port to check to see all monitors/sensors are ready. From what I recall in researching, they don't have any sniffer anymore. Don't think they do anything for visual either. Once you flash Stage 2, it should make your ECU ready to go.
