Looking to go Stage 2... NEED HELP!!! - Page 2
Results 16 to 30 of 37
This is a discussion on Looking to go Stage 2... NEED HELP!!! within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Sorry for the confusion....
    Aug 2010
    Palmyra, NJ
    Quote Originally Posted by careercadaver View Post
    I meant the Uppipe as far as wrap and STI set-up...I was half asleep...
    Ill correct my original post. I'd still wrap the DP though...with as many heat related issues to the number 3 cylinder and cv boots I'm surprised anyone would disagree with as much heat wrap as possible...
    Ahhhh uppipes! That makes more sense now
    Really isn't much need to wrap the UP though. But yeah, the 2006+ WRXs have the same UP has STI UPs- catless. While keeping heat in the pipes is a good idea, its more efficient at the turbo and DP level considering that's where exhaust gasses get superheated from turbo physics.
    I'm not disagreeing. However, there are some modifications I would make to your statement. First of all, the only part of the downpipe you want to bother with is to the point where it bends back under the firewall. Wrapping beyond that is diminishing returns; it will do pretty much nothing except cost you additional money. Depending on the wrap you choose (e.g., the newer Lava Rock wrap), you're not supposed to spray them (DEI).
    I'd wrap the exhaust manifold and uppipe (NOTE: you're not supposed to wrap a flex section; it can cause early failures) before wrapping the downpipe, if you're going to choose between them. Obviously, wrapping all three is ideal, but the turbo heat shield will do a good enough job. Pick up a turbo blanket down the line, which sometimes comes with some heat wrap, and use that as far as you can get on the downpipe and call it a day (otherwise, order a 2x15 roll).
    2005 WRX STi (Mods | Virtual Dyno) - Weekend Warrior
    Resident Tuner @ WTF Tuning
  5. #19
    Sep 2012
    CT
    Ok, thanks for all the input.... So if I purchase the cattless down pipe it would over boost? What will happen is it over boosts and will a catted dp solve that problem?
    Also what is all this external waste gate stuff. What does it do?
  6. #20
    Quote Originally Posted by atissasha
    A catless DP is not compatible with Cobb maps. If you deviate from the map notes, you can't expect them to support their product. Some cars will overboost. If that's a problem, reach out to them and have them resolve the issue.
    EWG puts the wastegate pre-turbo, and offers a larger volume of air to be dumped. This, in turn, allows for more power, and better boost control. It requires custom tuning, and should include aftermarket boost control. To go EWG, you're looking at ~$1000 bill.
  7. #21
    Sep 2012
    CT
    Thanks man... so if I buy a invidia catted down pipe. can i install it myself, and then run the stage 2 map from the ap? Will i need to buy a gasket aswell?
    Will it fit on the stock exhaust? Do I need anything else like as someone said earlier (boost control, up pipe etc...) which i know nothing about...
    Thanks!
  8. #22
    Aug 2010
    If you wan to run EWG that is part of the Uppipe selection. A popular choice for this is Grimmspeed though many companies make them with the bung for the EWG.
    I would also recommend them for the gaskets. Importimageracing sells a Grimmspeed gasket kit for a turbo swap. I would just do them all if you plan to do the Uppipe as well as you'll have it all apart.
    Have you read the FAQ the was posted early in this thread?
  9. #23
    Thanks!
    That would be sufficient for the Cobb map. If there are issues, you can reach out to them to resolve them.
    A downpipe isn't too difficult. It typically takes me an hour or two to do an install (which includes beer breaks with whoever I'm working with). You'll need a new turbo/downpipe gasket (get this from your local dealership). When utilizing the stock exhaust, you'll need an adapter (GrimmSpeed sells them); the adapter has a 3" flat flange where you can use a typical 3" gasket (GS sells these, as well), and reuse your stock 2.5" donut gasket on the other side.
  10. #24
    Sep 2012
    CT
    Ok cool. Would you mind copying and pasting the links on what i should order? Where should I get the Downpipe from? And is the invidia the cheapest option for a catted dp?
    Thanks
  11. #25
    Thanks
    Invidia is a good option; it's not the cheapest (cheaper options may have fitment issues), but it'd be the least expensive option I'd recommend.
    From what I talked about:
    GrimmSpeed
    GrimmSpeed
    Call your dealership about the turbo/downpipe gasket. They'll know what to order.
  12. #26
    Oct 2012
    Central, Pa
    Don't want to Hi-jack this thread but have a question.. If i were to go catless DP and run COBB OTS stage 2 map until I have the extra money to get a pro-tune (roughly 4 weeks) do I run the risk of damaging the engine if I don't "race" it.
  13. #27
    Sep 2012
    CT
    That is a good question... anybody?
    Quote Originally Posted by Ryno10rex View Post
  14. #28
    A question for Cobb; it's their map after all.
    - Al Stewart
  15. #29
            MainFrame's Avatar
    Austin, TX
    Damn.. I'm not even going to start on this one.
  16. #30
    Jan 2012
    Philly Area
    You guys say you don't mean to thread jack...but you are.
    - Will
