There won't be much difference between different DPs. Is your DP catted?
This is a discussion on Will it work within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Im installing a invidia devorced dp and and running with cobb ap on a 2012 sti sedan. Has anyone done ...
Im installing a invidia devorced dp and and running with cobb ap on a 2012 sti sedan. Has anyone done this and what was the results also any issues. I just wonder if the results are dramaticly diffrent from the cobb dp.
Thanks
2006 WRX
2012 WRX STI
- Speed never kills anyone, Suddenly becoming stationary, that's what whats gets you. Jeremy Clarkson.
Scott
Cobb maps require a catted unit. Is the one you're considering catted? If so, it should work. You won't see a difference in catted units until you start getting into custom mapping, and turbos bigger than the stock unit. Catted vs catless also becomes more apparent here, as well.
no its not catted i was just concerned because the invidia is devorced and the cobb is bell mouth.
2006 WRX
2012 WRX STI
- William
Focus less on the design of the downpipe/turbo flange than the fact that it's catless. If you go with a catless downpipe, Cobb has every right to say GFY when you call them asking for customer support, when you choose not to follow the map notes.Originally Posted by Rico2611
True... If wanted to run the stage 2 map with the dp and stock catalytics think i would have an issue.
2006 WRX
2012 WRX STI
disregard bad idea.
2006 WRX
2012 WRX STI
The stock catalytics are in the downpipe. If you have an uncatted dp, then you have no cats. Cobb's maps don't support being uncatted.
- William
You could use an accessport and a map from torquedperformance. His maps you can run catless.
2012 DGM 5 DOOR WRX
Mods: Stage 2+
"I live my life a twelve year old at a time. For those ten seconds or less, I'm free."
Official ClubWRX Creeper
I had a catless and a cobb downpipe... no issues.
You can over boost, or have boost creep... but that's something cobb is usually good about helping you with. Boost creep may not be solvable with their maps due to wastegate design
