Quicker Response Faster Car
Results 1 to 15 of 18
This is a discussion on Quicker Response Faster Car within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I have a 2002 WRX with a load of mods (327awhp). VF39 turbo 850cc injectors 2.2 Liter Bored WRX motor ...
    Jan 2010
    VF39 turbo
    850cc injectors
    Grimmspeed Uppipe w/38mm EWG
    Full 3" TBE
    FMIC
    Perrin Intake
    APS Turbo inlet house
    and a bunch of over stuff but those are the relevant ones here.
    I drove me friends '07 STi and loved how it just gets up and goes. Torquey all through the rev band especially down low from idle. My WRX however, off the line without launching it my car doesn't get going till 4.5K RPMs. It is a slug in turbo lag. I was wondering was gives the STi that "GO" characteristic. Is it the gearing in the transmission? Is it the AVCS heads? Is it the 2.5L short block? Is it all of those? If I wanted my car to respond better what mod would be best? Is AVCS going to make a big or rather noticeable difference?
    Thanks peeps!
            MainFrame's Avatar
    Austin, TX
    Extra displacement along with AVCS.. You're looking at several thousand dollars to implement AVCS, you would be better off buying a STi.
    BTW, where did you get a 2.2L WRX motor? I wasn't aware they ever made a 2.2L for the WRX.
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    You never mentioned what tune you have. Have you pulled logs and checked for any boost leaks/timing issues?
    Have you done compression/leakdown checks after the engine build?
    2007 Outback 3.0R wagon
    Oct 2010
    Portland, OR
    There are 2.2L stroker kits.
    Palmyra, NJ
    machined 2.0L to 2.2L...I've seen it.
    You have the same turbo as an STI (04-06 STIs anyway...the 07 STI VF43 doesn't make any difference in power)...but you won't make the same torque, which is probably the 'get up and go' you are feeling, as an STI since you don't have the 2.5L block.
    You're also likely seeing lag due to the pressurization needed for the FMIC. Go back to TMIC.
    An 18GXT turbo upgrade with a Processwest or comparable TMIC would be very nice, and a simple step up considering you already have the injectors (do you have a better fuel pump?)...and of course a proper tune for it all.
    Jan 2010
    The motor was the compression tested before tuning. There are no boost leaks in the system.
    I had a 2L ej20 took it to a machine shop and had it bored to 2.2L.
    I have a Walbro 255 fuel pump.
    Palmyra, NJ
    Yeah I'd rethink the FMIC then...what model do you have?
    And a turbo upgrade...
    Apr 2007
    8000' up in Colorado
    ^^^ what he said.
    And you need to get some suspension and braking mods asap to support the extra power if you haven't already...
    Scott
            MainFrame's Avatar
    Austin, TX
    Wouldn't that remove virtually the entire steel sleeve, leaving the cylinder wall weak as hell? I mean, if you look at the case halves, there is hardly any sleeve there to begin with. I had my ej257 bored from 99.5mm to 100mm (which is as high as you can go without totally ruining the sleeve), and that added practically nill as far as displacement. I know the ej205 has a little thicker sleeve to start with, but nothing near .2L thick.
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by Rambo View Post
    The common stroker kit uses an ej257 crank and is only 2.1L..
    Palmyra, NJ
    I think it had been done with one of the rare fully closed deck blocks though. I thought the EJ205s were only Semi-closed.
            MainFrame's Avatar
    Austin, TX
    Might you possibly be thinking of the 90s 2.2L Legacy turbo blocks? The ej22t was closed deck, and it was 2.2L from the factory. I've never heard of a closed deck 2L Subaru motor. ej205s are open deck, not semi-closed.
    You can take an ej205 and have it bored .2(mm) over.. but that doesn't effectively and any displacement, certainly not two tenths of a liter..
    Palmyra, NJ
    Yeah I think it is the older Legacy blocks. I know the closed deck blocks were relatively rare. I'd tend to agree more with what you say anyway. You know this stuff better than me.
    ClubWRX.net Vendor adam@kronosperformance's Avatar
    Nov 2005
    Princeton, NJ
    Re: Quicker Response Faster Car
    I would add some cams and headers to it along with a retune let your tuner know what you want to achieve with the car. You already have a good set of mods I wouldn't change the inter cooler as some suggested, its all in the tune and cams and headers would make more power as well
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by KronosPerformance View Post
    $4000 is a lot to spend on a car with a vf turbo just to pick up a little response time. And any aftermarket cam choice would only result in less low end grunt. The only cams he could switch to that wouldn't further kill the car's lack of torque below 4000rpm would be STi cams, and the only gain there would be after 4500rpm. Even doing headers would probably push the powerband further to the right, which is the opposite of what he's wanting.
    If we're talking about those amounts of money, why not build a 2.6L stroker with an ej257 block and put a Blouch 16g on it? That would actually help low end torque, although the 16g would choke like mad up top.. but that doesn't seem to be the OPs concern.
