Quicker Response Faster Car - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
This is a discussion on Quicker Response Faster Car within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; If the EJ205 was bored to 2.2L, that's your answer right there. The extra displacement is less the reason for ...
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    If the EJ205 was bored to 2.2L, that's your answer right there. The extra displacement is less the reason for the torque on the 2.5L as the longer stroke. For example, a 2.1L stroker motor (EJ205 case and EJ25x crank) will produce a similar powerband as the 2.5L with quicker spool compared to the EJ205. Increasing the bore without addressing the stroke is good for an exceptionally high-revving motor, which is usually counterproductive to producing low-end torque. AVCS surely doesn't hurt torque output down-low, but a higher CR 2.5L hybrid will produce more torque (more cylinder scavenging) than an AVCS-equipped 2.5L EJ255/257 with similar modifications.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
            MainFrame's Avatar
    Austin, TX
    There we go.. 2.6L stroker, STi cams, smooth off the edges on the combustion chambers (but try not to remove much material), port and polish, high compression pistons, OEM head gasket, ported exhaust manifold, 16g. Aim for 9.5-9.8:1 CR. Ditch the FMIC for a PW TMIC (FMIC isn't helping your cause at all).
    Get it tuned on e85.. it should have some grunt then!
    zax
    zax is offline
    Nov 2008
    Holy piss that would have a ridiculous amount of torque....
    Facebook me here
