Virtual Dyno?
Not accurate at all haha. Sorry.
This is a discussion on Dyno sheet? virtual dyno within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; hi guys done a log today how accurate do use think this is? smoothing factor at 6, on board weight ...
smoothing factor at 6, on board weight around 185- 200kg (400lbs) (thats 2 people inc driver and a bag of tools in the boot)
ambient temp 17 degrees celcius
boost creeps abit, top end richens up alot (maf needs some work)
320whp?!?
im happy about these results but how accurate do you think it is?
Virtual Dyno?
- William
It can be useful if the information is input correctly. Were you only logging RPM, TOA, PSI, and WBO2? Was "Fast Polling" on?
Notice how it TQ/HP doesn't cross @ 5252 RPMs? That graph is useless.
Might want to do a comparison of your own before you knock itIts closer than you think buddy. Its been compared to a lot of DynoJets nationwide.
I do agree that this graph isnt accurate because its showing two large humps in it even for smoothing of 6. I bet it is hiding two large spikes which are usually a result of crappy data from the logger. If you notice and manually analyze the data from an AccessPort in fast logging mode. Its complete garbage.
i did a 3rd gear pull ive used other pulls aswell around 290 - 300 whp but this one is the highest ive ever gotten after i tweaked the map abit i loged the following
engine load
engine speed
iam
ignition total timing
knock correction advance
manifold relative pressure direct
mass air flow g/s
mass air flow voltage
throttle opening
feedback knock correction
fine learning knock correction
innovate wideband afr
i had alot of parameters because i didnt do this pull for the dyno i was just checking up on the map i tweaked abit
If that dip is indicative of your average pull, you need to work on your tune.
That doesn't sound safe at all..
lol :P it only affects wot sometimes otherthan that its okk
For now it only affects WOT sometimes. Anything that gets in the way of normal pedal movement is extremely dangerous. How do you know when it might get in the way of braking normally for the first time and what situation you'll be in? RIP in that case...
I'd say that graph is pretty useless. Maybe it's somewhat accurate, maybe it's not, but in reality you need a real dyno run to get any useful information.
Scott
For where I was going with my comment, see below.
But for what it's worth, I've also read a number of anecdotes about getting inconsistent results with virtual dyno. But what I really meant was it is absolutely no replacement for a real dyno. Sorry I wasn't clear.
- William
There are nay sayers in every group. Virtual Dyno only reflects readings that the logger records. If the user is not aware that hills and taking a log while on an interstate on ramp is a bad idea. I cant code for those scenarios. User error accounts for a lot of the 'bug reports'. I will agree that most dynos are a better way to get information. I will preface this with the fact of it only being true if the dyno operator isnt a complete moron. Ive seen them lead people into thinking they were making power that they werent.
Now as far as a tuning tool there are SEVERAL people using this for what its meant for which is showing power before and after mods. That is what a dyno is for actually. The community consistently misuses dynos and virtual dyno by thinking they are to compare cars on peak power. Now I could go on and on about misuse and things Ive seen done but that isnt going to change your mind. I will leave you with this though. Who wants to drop 70$ on 3 pulls when you can get Virtual Dyno for free and make a few passes and tune and then get the final numbers from one dyno session instead of 2-3 sessions. Virtual Dyno saves you money in the long run and saves a lot of people from having to drive hours to the nearest dyno. So I wouldnt write it off yet.
One thing that baffles me is why is the subaru market the only market that whines about a free tool that has been proven to be pretty darn accurate and its FREE!!
Also if you notice he is using newton meters of torque instead of foot pounds which will not cross at 5252 ... just noticed this based on the comment above.
