Page 1 of 5 12345 LastLast
Results 1 to 15 of 67
This is a discussion on Questions on stage 2 upgrade (downpipe/ap) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I have a 2013 WRX. I'm currently getting a nameless axle back muffler delete as my first mod. In the ...
    Registered User pauller's Avatar
    Oct 2012
    West Florida
    I have a 2013 WRX. I'm currently getting a nameless axle back muffler delete as my first mod. In the coming months I would like to do more. Definitely getting a cobb ap, but then looking at downpipes. An invidia catless dp is only about $300 whereas a cobb dp is about $600. I'm not looking at the cobb because it's too expensive. So could I use the invidia catless dp with a cobb ap map or would I have to get a custom map/tune? Also, I'm in Florida, so there's no emissions testing
    And how loud would a muffler delete be along with a catless dp? What kind of performance increases would I be looking at too? Thanks in advance
    pauller
    2013 Stage 2 SWP WRX Sedan
    Invidia Q300 Ti Tip-Tomei 3in Catless Downpipe- Cobb AP w/ Stage 2+ 93 Map-Cobb SF Intake
    Registered User starkall's Avatar
    Sep 2010
    You'd need a tune, and muffler delete with catless will be pretty loud. But you'll see pretty good gains and will notice a lot more power.
    Registered User 11blackwrx's Avatar
    Sep 2011
    Akron, OH
    I say do it lol, im running an invidia catless dp and an N1 race which has no resonators and just one muffler. its loud and sounds great i have yet to get in trouble for it
    2011 Subaru WRX Premium
    1988 Ford Mustang GT
    2000 Jeep Wrangler TJ
    Oct 2012
    West Florida
    So I'll get the DP and get a tune, but then will any maps from the AP work with the DP? If not, where do I get them?
    pauller
    Sep 2011
    Akron, OH
    the map i went with was a stage 2 from torqued performance, i would be cautious with a catless dp because it can lead to boost creep, i just a few weeks ago installed my catless dp and im going to have a local tuner help adjust the tune to avoid boost creep. but im sure that torqued performance can tweak the tune to avoid this as well
    Registered User matsayz's Avatar
    Apr 2012
    Vegas
    You should get a pro tune if you put the downpipe on. Also, have you heard this exhaust in person? It's highly suggested, try to find someone at your local Subie meet up. I bought a 2nd hand Namless with the Magnaflow and it sounds great, louder than stock but not obnoxious. If you want an idea on how loud your car will be, drop your stock muffler setup and drive around the block... It'll sound like a rally car.
    Oct 2012
    West Florida
    Boost creep! Forgot to mention that. So how big of an issue is it? (Sorry for the bombardment of questions...)
    pauller
    Sammich Makin' Princess Leia wrxtreme06's Avatar
    May 2007
    orlando flawduh
    IIRC, the OTS cobb stage 2 map is designed for catted downpipes. not sure about any other stage 2 maps though [torqued performance, perrin, etc]
    might be best to ditch the AP altogether and just get an opensource tune or if you're set on getting the AP, get a protune like the others suggested.
    desiree
    06 impreza wrx tr
    : cobb stage II - protuned by STi_Mikey!
    hawk-eye alliance #11:11 //
    wingl3ss @ll!ance #17 // lvl 80 N.E.R.D.
    facebook
    Jan 2012
    Philly Area
    Quote Originally Posted by pauller View Post
    On the 3rd gen cars, a catless dp often leads to boost creep. You don't want that happening, as it could get into dangerous levels of boost.
    - William
    Oct 2012
    West Florida
    I'm guessing it'll be pretty damn loud. I think I'll like it though. I'll look around and try to hear a similar setup. I have time to make sure I really like it too (about a month til I actually order it.)
    pauller
    Oct 2012
    West Florida
    Can a tune prevent it at all? Or is it always going to be there.. I picture it as something insidious
    pauller
    Dec 2011
    Pottstown PA
    this is mostly an issue on third gens? how about bugeyes-hawks?
    Jan 2012
    Philly Area
    From what I understand, a tune can put a bandaid on it, but that would be by limiting the tune. I'm no expert though.
    Quote Originally Posted by Ruh Roh View Post
    From what I've read, its just more likely to happen with the 3rd gens, but can happen with anyone.
    - William
    Dec 2011
    Pottstown PA
    ahh yea i was going to put a catless dp on and im still using the cobb ap stg 2 maps..but isnt there a map like high wastegate or low wategate that has something to do with boost creep issues? or maybe not hitting full boost issuse..hmm opening up another topic there so nvm
    zax
    zax is offline
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Boost creep [most often] means that the wastegate is not able to open completely or is sized too small for the amount of air the motor is flowing, allowing the boost to continue to build past the target boost. With the WRXs prior to 2009, the Mitsubishi turbos have an adjustment on the wastegate actuator arm. However, VF series turbos do not have this adjustment. There are a few ways around this:
    1.) Replace the IWG with EWG (this requires a tune regardless)
    2.) Replace the IWG spring (there are threads on how to do this with STi turbos, the same concept applies to the VF52)
    3.) The boost control is a PI (proportional, integral) closed-loop control system. There is an equivalent to anti-windup within the Turbo Dynamics tables. Tuning this MIGHT remove the boost creep. However if the boost creep is truly caused by the wastegate not opening completely, there's not much you can do from a tuning perspective.
    Truly, the best solution is to add a little bit of back-pressure (i.e. high-flow cat) to decrease the pressure differential across the turbine. Running a LWG or HWG map is only for target boost, not for boost creep/wastegate creep (which can be easily tuned out with Turbo Dynamics)
    Facebook me here
