Page 1 of 3 123 LastLast
Results 1 to 15 of 38
This is a discussion on Intake issue on a 2013 wrx within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; first of all I am not sure if this is the right spot for this thread, if it isnt please ...
    Jun 2011
    first of all I am not sure if this is the right spot for this thread, if it isnt please slander me on the internet until the end of time, or till i fix it and put it in the right spot, but if it is the right spot then
    So this is whats going on, i just got a new Cobb SF shot ram intake for my 2013 wrx, install went easy but my car does not like the intake at all, at higher RPM's it stutters and runs rough, double checked everything, disconnected the battery during install, so im not sure whats going on. anyone have any ideas? i remember seeing someone saying that if you install anything you should get your ecu tuned to work with it, i didnt think that installing a intake would make my car run that bad ~_~
    mind you my other cars i worked on was a 95 GS-T Eclipse and a 2004 wrx which both took the new intakes like champs. so any help to this issue would be great, thanks all!
    Registered User vu_tang's Avatar
    Sep 2011
    Your ECU doesn't know what to do with all the extra air. You are damaging your motor without a tune. Uninstall the intake or get a tune before you do long term damage.
    Jun 2011
    see thats what i figured, makes me sad, im so use to just install and go, boo lol.
    Jan 2012
    Philly Area
    You absolutely must tune for an intake on the 3rd gen cars.
    That said, it almost sounds like there could have been a leak too.
    - William
    Registered User shadidd's Avatar
    Jun 2012
    Las Vegas
    Cobb AP is what you need.
    Sent from 125mph
    Registered User jilty's Avatar
    Aug 2012
    Southern California
    I picked up the same intake with the box from a buddy 2 weeks ago, just waiting on Cobb to take my money once the 2013 maps are out.....told me they are waiting on 2013s to test on....if only I lived in texas.
    Registered User starkall's Avatar
    Sep 2010
    Cobb has stated that a tune is not required for their intake but highly recommended to get the power gains of the intake. Rallysport direct says the same. As long as the intake has the same size Maf tube it'll be ok but I still recommend a tune to get the performance gains of the intake.
    zax
    zax is offline
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    I doubt it's the intake. Cobb has designed the SF intake to mimic the airflow of the stock intake across MAF sensor. Are you sure that you installed the MAF correctly (not backwards) and that it's connected? Any CELs?
    Facebook me here
    Registered User Yamahar6311's Avatar
    Aug 2012
    Los Angeles
    You'll run it too lean if you keep it. Need AP STG 1 map
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by Yamahar6311 View Post
    Do you have any empirical data to prove this statement? Or are you just regurgitating what you've heard?
    Facebook me here
    Aug 2012
    Los Angeles
    Yes sir. I have the same intake. And when I first got it and didn't have the AP the check engin light came on and it clearly reads lean
    Sep 2010
    You can run the SF intake without a tune and it will be fine. But it provide no performance gains and be a just a noise maker until tuned.
    zax
    zax is offline
    Nov 2008
    Do you have a wideband O2 sensor installed? If not, you cannot make this judgement. A "System too lean" can mean a number of things.
    Facebook me here
    Aug 2012
    Los Angeles
    Once again, I'm just going from what happened to me. My opinion is just one of many. It's up to the person who started the post to make their decision.
    Aug 2012
    Los Angeles
    And how does this mean a number of things? It's an in your face answer. It's a 2013. Not a 1993, what the hell else could it be???
