Results 1 to 8 of 8
This is a discussion on My turbo is dead within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hi everyone Like the tittle says my turbo is dead on my Subaru WRX 2002. I'm looking to get a ...
    Jul 2012
    My turbo is dead
    Hi everyone
    I'm looking to get a new turbo, but I don't really want to go with something that wont be bolt on.
    My WRX used to be a stage 2 with 265 HP with the original turbo working.
    Anyone has any suggestion about what I should get and would be bolt-on on the parts I already have ?
    Thanks
    Dave
    Registered User sxcrxy's Avatar
    Nov 2011
    Quote Originally Posted by leoleking View Post
    Hi everyone
    Thanks
    Dave
    what makes you say its dead? whats your budget? what gains are you looking for? do you want bottom end with no top end power or vice verser, there are many of turbo's that are straight bolt on, you have to change your injectors and fuel pump if you put a bigger turbo on aswell
    Jul 2012
    Yeah sorry I did forget to put some info there.
    The turbo is making some king of metal noise just like if metal was shaffing.
    I think the shaft is loose or something like that.
    When the turbo begins to get hot, it stops to boost.... I can hear a leak.
    It has 160 000 km.
    So I'm guessing it either needs a rebuild or it needs to be changed.
    So I am looking for something that is like the original one, maybe a bit better but I don't want to have to change the injectors and the other things I would need to change if I get a bigger one. I do not have a lot of money to put on it for the moment.
    Stock turbo is the only thing that will be bolt-on (in that you won't require other modifications).
    Jul 2012
    ok thanks
    Nov 2011
    hmm i have a 02 my stock turbo laster 175 000 k's then i upgraded just for more power
    Jul 2012
    what turbo you put in your car?
    what did you modify ?
    how much did it cost you approx.?
    Re: My turbo is dead
    You said you weren't interested in replacing injectors. That limits you to the stock turbo.
