Pistons - Page 2
Results 16 to 30 of 40
This is a discussion on Pistons within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by interhead77 It's wet sometimes and it's dry other times but the ticking and loss of pressure is ...
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Re: Pistons
    Quote Originally Posted by interhead77 View Post
    It's wet sometimes and it's dry other times but the ticking and loss of pressure is what concerns me. I know there's definitely something wrong there.
    I'm confused. Are you or aren't you burning oil?? 7 PSI is wastegate pressure likely suggesting the ECU is pulling boost. This could be a number of things. Please list ALL of your mods and how the car was tuned. As for ticking... have you ever heard another Subaru boxer motor up close? It's probably normal.
    Beamed at your face at approx. 186,000 miles per second via DROID BIONIC
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
            MainFrame's Avatar
    Austin, TX
    Loss of oil pressure, or boost pressure? Boost pressure doesn't really have anything to do with your oil. But if you have a cracked ringland that would explain loss of power and oil consumption. Blown turbo seals would normally cause it to smoke like mad.
    Registered User interhead77's Avatar
    May 2012
    Eatontown, NJ
    Loss of boost, I feel like the car should be faster then what it is, it's not particularly slow but it doesn't come. Close to the rx7 I have which doesn't make sense because it should be close to as fast especially with upgraded exhaust system upgraded turbo and injectors and upgraded intake. Like I said though its not really tossing oil out the tail pipe and it only smokes a little when i start it, and it definitely is consuming oil.
  6. #19
    May 2012
    Eatontown, NJ
    Isn't consuming oil**
  7. #20
            MainFrame's Avatar
    Austin, TX
    Then it sounds like either the car isn't tuned properly, or the boost control system is not working properly. No way we can help with that without knowing what's been done to the car.. data logs would help a lot too.
  8. #21
    zax
    zax is offline
    Nov 2008
    Pistons
    Don't bother asking any further questions until you have answered this one.
    Facebook me here
  9. #22
    May 2012
    Eatontown, NJ
    So I opened up the manifold up and found that there is a very minimal amount of oil inside of it. Basically just a mist covering the mouths.
  10. #23
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    What mods do you have?
    <-------- Taylor Swift.
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
  11. #24
    May 2012
    Eatontown, NJ
    a deadbolt monster td04 turbo, cold air intake, sti top mount intercooler, stainless steel downpipe and full exhaust, sti injectors, and a mishimoto radiator. as for the tune i have no idea whats going on with the tune i bought this car and im the 9th owner of it so its probably got a really wacky tune considering the car was beat half to death. i mean the idle even sees to low sitting at 400-500 rpm.
  12. #25
    zax
    zax is offline
    Nov 2008
    Re: Pistons
    The tach only reads down to 750rpm. You NEED to get the car tuned ASAP. 9th owner?!?
    Facebook me here
  13. #26
    May 2012
    Eatontown, NJ
    yes sir im a poor bastard and i love the subaru so what better way to get one then pay 4750 for a beat one and nurse it back to health. i got one cheap, one less ******* has one and we can feel better now that the car is in caring hands.
  14. #27
    Registered User DorBink's Avatar
    Sep 2009
    Houston, Katy
    I appreciate u bought the car cheap but ur going to need to drop some cash to sort it out. Be prepared to pay 500 to 600 for a tune or more depending where u live. Make sure you prep ur car before you get it done. They will ask for a list of all your mods or they might charge you more for a full inspection etc of your car. The tuner will probably point out if there are some major problems. Good luck!
  15. #28
            MainFrame's Avatar
    Austin, TX
    You need to do compression and leakdown tests, if that checks out then boost leak test, make sure the entire car is up to maintenance (timing belt, water pump, tensor, plugs, all fluids, etc). After that's all done then you need to get it professionally tuned by a reputable Subaru tuner.
    Until you have done those things, I wouldn't drive the car..
  16. #29
    May 2012
    Eatontown, NJ
    Well I've been driving it I hope nothing got messed up during the course of these problems although the timing belt water pump thermostat and radiator are all new.
  17. #30
    May 2012
    Eatontown, NJ
    so i put the manifold back on and the car wouldnt start. i went back and took everything apart and found that all of the bolts' threads were severely stripped so there was no force holding the manifold down. on tom of that one of the fuel lines a\had been bent till the point that it folded and closed off. i went ahead and redid all of the bolts and cut the fuel line and attached a fuel line to the cut piece. once properly mounted together the car started right away! not only that but the rpms were good starting at 1500 for cold and about 600 700 for hot. it also sounded a lot smoother more of a brrrrrrrrrrrrrrrrrrr sound as apposed to the brub brub brub brub sound it was making before. turns out i had some serious vacuum problems but i do still think the car needs a tune...
