Results 1 to 15 of 23
This is a discussion on Is inlet swap hard? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; What's the pain in the ass level? Is it worth the money to switch to an aftermarket inlet? I have ...
    Registered User kevo0311's Avatar
    Dec 2011
    so cal
    Is inlet swap hard?
    What's the pain in the ass level? Is it worth the money to switch to an aftermarket inlet? I have a terrible boost leak somewhere. I just started noticing hitting peak at only 13.4 when it should be 16 to 18 lbs. I'm attempting to hit 400whp by getting my 73mm shorty. I have an 06 tr, FMIC with a amr cxr500 10.5"cm.
    Sent from my ADR6350 using Tapatalk 2
    ClubWRX.net Vendor KronosPerformance's Avatar
    Nov 2005
    Bordentown, NJ
    It really depends on your skill level. Its not rocket science but it can take a bit.
    If you go with a hard inlet, you will have to loosen the intake manifold to get it to fit properly.
    If you get a soft / silicone inlet (example: Perrin) then you can install it without loosening the manifold.
    Here is Perrin's instructional video:
    http://www.google.com/url?sa=t&rct=j..._BtRHQpkSI5eVQ
    ClubWRX.net's #1 Vendor! - www.kronosperformance.com - Call/Text 732-742-8837 |
    AIM Screenname - KronosParts | GoogleTalk - sales@kronosperformance.com | Military Discount
    [/SIZE]
    USE COUPON CODE FIRST5%OFF to receive a discount of your first order
    Kronos has Special Pricings on Process West & Agency Power!
    CONTACT US DIRECTLY FOR SPECIALS AND PROMOTIONS
    Dec 2011
    so cal
    Re: Is inlet swap hard?
    My skill level is beginner but looking at it, it looks simple
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    not beginner level buddy. It'll have you cursing pretty hard. But we were all beginners at one point. I've never taken a mechanic class in my life... and I managed to pull an entire engine and put a new one back in. So if you're willing to put forth the effort, and you have more than one day in case something goes wrong... then go for it.
    Why are you upgrading?
    Registered User sxcrxy's Avatar
    Nov 2011
    i did it my self took a couple hours , all i can say is patience and a cold drink is gonna be your bestfriend its not that hard putting or taking the old one out, the hard bit is getting the recirce pipe on there :/ the gains are maddddd especially if your running a bigger maf spool up is nice and quick
    Registered User sjcurtis's Avatar
    Sep 2010
    Selma, Alabama
    It took me about 3 hours to get the intake manifold off just because I didn't know where all the wiring harness plugs was located so I just took my time. The second time I pulled one off it only took about an hour and I had it sitting on my work bench. The big issue is getting the inlet lined up with the turbo because of the offset on the coupler but once you get it lined up where it is supposed to be you are golden. Oh yeah it would be a good idea to get new intake gaskets before hand. I installed the Grimmspeed gaskets, phenolic spacers, and the AMR turbo inlet at the same time.
    Oct 2011
    Santa Ana, CA
    I'm mechanically capable... at best. Did it in ~4 hours. Side effects:
    Knees sore as hell.
    Back sore as hell.
    Busted knuckles.
    Taught neighborhood kids new swear words.
    Replacement radiator, broke the turbo reservoir return nipple with my ass during install.
    Mine was ripped at the turbo, I would check the front mount piping first.
    You're welcome.
    Dec 2011
    so cal
    I'm thinking an ass level of 7 lol. Thanks everyone.
    Dec 2011
    Pottstown PA
    didnt realize it was going to be that hard lol. everyone said the uppipe install was a pita and it wasnt too bad lol
    zax
    zax is offline
    Moderating the World! zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    I hope you set aside $$ for a new transmission. Your stock tranny will likely not last the first few miles at 400whp and that work will be much more of a PITA over the inlet.
    Beamed at your face at approx. 186,000 miles per second via DROID BIONIC
    Facebook me here
    Dec 2011
    so cal
    If i shift right i think i can make my transmission last pretty long i dont run threw the gears like a 6 speed. Its all highway miles, never dumped either
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by kevo0311 View Post
    Ok you're the expert...
    Facebook me here
    Aug 2012
    Bristol, CT
    WRX can't really handle much more then 300 from what I've heard. They barely hold there own stock...dump your clutch a few times and see what happens
    I wanted to do a throttle body service on my car...I will probably never ever ever do that again
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by nsibanez View Post
    Torque is what kills transmissions. With the 2Ls, one could get away with about 330-340whp on the stock tranny since you're only looking at about 300-310 wtq peak. With the 2006-2007 3.7 F/D 340whp would be about 340-350wtq and potentially very lethal to the transmission. Not sure why Subaru went to the 3.7 F/D with 1.1:1 center diff gearing reduction, but it seems to potentially increase the mechanical stress on an already weak design...
    Facebook me here
    Quote Originally Posted by zax
    GTFO with your logic...
