Results 1 to 14 of 14
This is a discussion on Popping coming from exhaust. Downshifting within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hi I've noticed sometimes (not always) I get a popping sound from the exhaust when Im downshifting from 2 to ...
    Registered User DorBink's Avatar
    Sep 2009
    Houston, Katy
    Hi
    I've noticed sometimes (not always) I get a popping sound from the exhaust when Im downshifting from 2 to 3 usually coming off the freeway. Just wondering if I should worry about this? Or does anyone know what this would be?
    Mods: turbo back exhaust, cat less up pipe and I have had it pro tuned.
    I never noticed this until I did the last mod for the up pipe and pro tune but I never noticed this immediately. Like 3 - 4 months later
    Thoughts?
    Aug 2012
    Bristol, CT
    How do you downshift from 2nd to 3rd?
    Depending on what type of popping, more then likely normal. A lot of aftermarket exhaust sytems do this...don;t know why, would love to if someone wants to fill that part in
    But worse case scenario it's misfiring. But you would throw a CEL if it's misfiring
    Registered User shadowpr's Avatar
    Jan 2011
    TX, NY
    is it a little backfire?
    Aug 2012
    Bristol, CT
    Quote Originally Posted by shadowpr View Post
    Sounds like it would be. Especially if there's no CEL codes.
    ClubWRX.net Vendor KronosPerformance's Avatar
    Nov 2005
    Bordentown, NJ
    Catless downpipe?
    ClubWRX.net's #1 Vendor! - www.kronosperformance.com - Call/Text 732-742-8837 |
    AIM Screenname - KronosParts | GoogleTalk - sales@kronosperformance.com | Military Discount
    [/SIZE]
    USE COUPON CODE FIRST5%OFF to receive a discount of your first order
    Kronos has Special Pricings on Process West & Agency Power!
    CONTACT US DIRECTLY FOR SPECIALS AND PROMOTIONS
    Registered User Terminal Kuz's Avatar
    Aug 2012
    SoCal
    You are probably running rich. Mine does the same thing but it depends on the mods you have and the tune.
    2005 WRX (Silver) SoCal Subie
    Blobeye Syndicate #1093
    http://www.clubwrx.net/forums/builds...al-05-wrx.html - Build Thread
    http://www.flickr.com/photos/34009765@N06/ - For whatever pics i take.
    Mikie13-Spend money on hookers and blow. That's a better intake.
    Aug 2012
    Bristol, CT
    Beats running lean
    Just out of curiosity, how does running rich cause it to pop?
    I can see, kind of, without a tune due to the extra air flow causing the ECU to need more fuel, and eventually it gets a memory for this
    Nov 2005
    Bordentown, NJ
    Quote Originally Posted by nsibanez View Post
    Beats running lean
    Excess fuel will carry along in the exhaust. Exhaust travels through the exhaust piping and fuel of course is flamable, so with a hot exhaust and fuel touching the piping, it will burn or pop.
    [/SIZE]
    Aug 2012
    Bristol, CT
    That's pretty cool. Personally, I like the sound =p
    Registered User Front Kick's Avatar
    Aug 2012
    The Dojo
    I'm catless and getting backfiring all the time. AP Stage 2 as well.
    To the face!
    04' Stage 2 WRX | Premium Silver. Premium Sex.
    Sep 2009
    Houston, Katy
    Hi
    No CELs. No misfire Yes cat less up and down pipes.
    The tuner did state and I have the graph that he tuned it more rich bc he said it was running lean. I was figuring it was un spent fuel making it out into the exhaust. Typically happens in high revs from 3 to 2. Saying that I think it's odd that maybe I should change my spark plugs since they are about a year old. I figure that should improve ignition?
    But overall based on the comments this doesn't sound like an issue
    Thanks for all of the comments
    Aug 2012
    Bristol, CT
    It really shouldn't be an issue. Wouldn't see why....lower gas mileage at the worst maybe?
    Aug 2012
    SoCal
    Took a look at your profile to see if you listed your mods. Definetly because of what you are running i have pretty much the same mods on my Rex also stage 2.
    Registered User 11blackwrx's Avatar
    Sep 2011
    Akron, OH
    yeah this is probably nothing more than backfire and not a major issue
    2011 Subaru WRX Premium
    1988 Ford Mustang GT
    2000 Jeep Wrangler TJ
