Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
This is a discussion on If I were to buy a new turbo... within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I actually debate this subject every couple weeks. First of all, numbers don't tell the entire story not only because ...
    Registered User Eric05mx's Avatar
    Oct 2010
    PA
    I actually debate this subject every couple weeks. First of all, numbers don't tell the entire story not only because of different dyno's and what not but 320whp on a VF52 is going to be different than 320whp on a Dom1.5 or 20G.
    I pretty much cancelled my plans of a turbo swap because of how much it will cost with all the proper supporting mods (which only make sense to do if your spending the money on a turbo & tune) and the block will need to be built down the road which is another few grand.
    2012 WRX ice silver metallic
    Protuned by Agile Auto 315whp/342wtq @ 20.5psi
  2. #17
    Jan 2009
    Md
    Quote Originally Posted by Eric05mx View Post
    Your mods were what again? TMIC CBE 3 port CAI, fuel pump? injectors?
    2012 WRX: TurboXS DP, AEM CAI, TP stage 2 tune
  3. #18
    Jan 2009
    Md
    I thought that these engines were good to about 400 whp? So why would you need to rebuild your block? I was going to stay around 350ish whp, but with the stock turbo 350 who seems to really be pushing it on the stock turbo.
  4. #19
    Texas, United States
    I wouldn't be trying for 400whp on a stock engine, in my opinion 350-360whp is the max I would push the stock pistons. Obviously the more power it makes the shorter the life of the engine, so yeah, eventually it will have to be rebuilt regardless.
  5. #20
    Jan 2009
    Md
    No, i'm not pushing for 400 whp. I don't need that much power... all i'm saying is that even if you could get to 350 whp or so on a decent dyno that the turbo would be pretty well maxed out would it not?
  6. #21
    No way you would get 350whp on a reasonable dyno with a stock turbo without at least e85.. and that's still pushing it. On pump gas, 300-305whp is what I would expect to see out of a VF turbo.
  7. #22
    Jan 2009
    Md
    93 is the best I can get here. I wish I had access to E85 honestly, but I don't... hence the reason I was wondering about a bit of a larger turbo just to add that power without maxing the stocker out. If I just have to add a fuel pump, injectors and do even a mild tune that's fine. The car doesn't have to be pushing some huge number. I just want a nice, reliable turbo IF what i'm looking for would make sense. In other words... if I would have to put in headers, an uppipe, and some of the other PITA mods just to make the stock set-up better, then it just makes sense to get a little larger turbo and just not push the boost to the max then i'm not really spending that much more money.
