Results 1 to 15 of 26
This is a discussion on Another uppipe question within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I'm going to get a new uppipe first, to keep my turbo running good. However, I've heard of gaskets and ...
    Oct 2012
    New Jersey
    I'm going to get a new uppipe first, to keep my turbo running good. However, I've heard of gaskets and what not. So if I am getting a new uppipe, what else do I need?
    Aug 2012
    Bristol, CT
    Quote Originally Posted by Weedity View Post
    What do you mean what do you need?There's never exactly anything you need, just what you want. Things you need are to service your timing and drive belts, oil changes, transmission and differential services, aliagnments...
    moar specifics please
    Dec 2011
    Pottstown PA
    if your going to keep the car stock the stock uppipe is fine, but if planning on going stage 2 upgrades and tuner a uppipe is needed so the cat doesnt fall apart from the higher boost pressure. i have a grimmspeed uppipe from kronos performance and ordered the 2 gaskets for it as well. FMS posted a link on your other post so check his out as well, theyre both great vendors.
    Re: Another uppipe question
    Uppipes let go at stock levels, too. It's a liability at any power level, but that has a direct correlation to power.
    Oct 2011
    Santa Ana, CA
    Agreed. My uppipe was clogged at 100-some K miles. Caused my turbo to make a nasty valve-line clicking sound.
    Posted from a fone.
    Oct 2012
    New Jersey
    Well, I was just wondering do uppipes come with gaskets? What are gaskets? Are they necessary? Do you need more then one? Do you just need the uppipe and gasket? It's all just so confusing to me lol, I'm new to this.
    Dec 2011
    Pottstown PA
    Oct 2011
    Santa Ana, CA
    Gaskets are necessary, the help seal the little cracks between the pipes.
    My dealer had to use multiple OEM gaskets when they did my uppipe, 1 caused a nasty exhaust leak. I was overboosting like crazy.
    If it is confusing to you I would recommend paying someone to do it for you. Its a pain in the pass part to install, compared to other stuff. And a bad install could mean POP, goes the engine.
    Aug 2012
    Bristol, CT
    Quote Originally Posted by UEDan View Post
    Too much back pressure?
    How do you get a bad install? It's either tight, or not tight right? If you don't mind me asking, just out of curiosity
    Oct 2011
    Santa Ana, CA
    Not enough probably. You're right, they said the downpipe wasn't torqued down correctly. So my turbo was probably dumping it's exhaust gas out with no restriction, at a rate the wastegate wasn't setup for.... overboosting. Their f-up. Just took it back. No charge.
    The "correct" procedure to replace an uppipe is to remove the downpipe btw.
    FMS
    FMS is offline
    ClubWRX.net Vendor FMS's Avatar
    Jul 2012
    Chicago IL
    The uppipe does require that you replace the gaskets and does not come with new gaskets. These will need to be ordered in addition.
    GrimmSpeed Ceramic Coated Uppipe Subaru 2002-2012 WRX / STi - Flatline Motorsports
    GrimmSpeed Lower Uppipe Gasket Subaru Tuurbo Models - Flatline Motorsports
    GrimmSpeed Gasket Uppipe to Turbo - Flatline Motorsports
    Another thing, we are also running a sale on anything exhaust related (use voucher in cart: bheard1221) . Feel free to PM us with any questions for immediate answers.
    OPEN 7 Days a week|We match and beat advertised prices and sales|855.447.8288
    AOL Instant Messenger: FlatlineMotorsports.mason@gmail.com
    Link: Flatline Motorsports Online Store
    Link: Flatline Motorsports Facebook
    Texas, United States
    Gaskets, 2.2K Ohm resistor, electrical tape, PB Blaster, tools, beer.
    Dec 2011
    Pottstown PA
    yes +1 to PB blaster
    Dec 2011
    Pottstown PA
    also i drove my car up on ramps to do this install and had to use a jack to lift the motor off the mounts to pull uppipe out.
    Aug 2012
    Bristol, CT
    Quote Originally Posted by Ruh Roh View Post
    Just bang it with a hammer
