Another uppipe question - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
This is a discussion on Another uppipe question within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by FMS The uppipe does require that you replace the gaskets and does not come with new gaskets. ...
    Quote Originally Posted by FMS
    The uppipe does require that you replace the gaskets and does not come with new gaskets. These will need to be ordered in addition.
    Some uppipes do come with gaskets. However, many of the ones I've seen included don't look all that great, and the last thing you want to do is a second uppipe install because one of the gaskets blew out; therefore, I'd just buy a set of new OE gaskets. What gaskets you buy is determined by what install method you go with. Basically, if you break an exhaust seal, you need to use a new gasket.
    Resident Tuner @ WTF Tuning
    Oct 2012
    New Jersey
    Thanks for all the info! How many gaskets though, just one? Plus, I'm probably going to have someone else install this, like an auto shop or something.
    Aug 2012
    Tucson, AZ
    The more gaskets, the tighter the seal. Go with 4 or 5
  6. #19
    Aug 2012
    Tucson, AZ
    Just like drain plug gaskets. Got a stripped thread in your pan or plug? Just use more gaskets ;]
    No, really you just need one per side
  7. #20
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by nsibanez View Post
    Just bang it with a hammer
    that's what she said
  8. #21
    Aug 2012
    Tucson, AZ
    Ouch
  9. #22
    Quote Originally Posted by Weedity View Post
    It depends on how they install the uppipe. For every seal they break, they need to replace it with a new gasket. At a minimum, you need downpipe/turbo, turbo/uppipe, uppipe/manifold. You could also require head/manifold or manifold/crosspipe gaskets as well.
  10. #23
    Oct 2012
    New Jersey
    So like 2 downpipe/turbo gaskets, 2 turbo/uppipe gaskets, 2 uppipe/manifold gaskets, and 2 uppipe/manifold gaskets is good?
  11. #24
    Q RayfieldsWRX's Avatar
    Oct 2002
    The Old Folks Home
    This. I cheaped out and used the provided gaskets when I did my last uppipe. The lower blew out, and I sounded like a tractor going down the road until I got an OEM piece in there.
    --Ray
    2013 Subaru BRZ Limited
    2002 Subaru WRX Bugeyebrid Wagon -- SOLD
    2002 Subaru WRX Sedan -- SOLD
  12. #25
    Aug 2012
    Tucson, AZ
    EJ257, I see your avatar, and sorta pee a little every time.
  13. #26
    No. If you're not DIY installing, then you need to talk to the shop to find out which gaskets you'll need.
