HELP PLEEEASE!
Results 1 to 15 of 15
This is a discussion on HELP PLEEEASE! within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; so today i went to reflash my ecu as it was i got the bsod (blue screen of death) so ...
    Registered User sxcrxy's Avatar
    Nov 2011
    HELP PLEEEASE!
    so today i went to reflash my ecu as it was i got the bsod (blue screen of death) so i tunred the key ignition off wasnt a smart move, now my car is stuck in cycle mode please tell me i didnt brick it (its my daily) i cant do anything via ecu flash please is there a way how to fix it? i am desparete
    You never shut off power to the ECU in the middle of a reflash (failed or not). Can you power your laptop back on and reflash?
    If not:
    How to Unbrick an ECU. Like A Boss! - NASIOC
    Resident Tuner @ WTF Tuning
    Nov 2011
    If not:
    i didnt i got the blue screen of death and turn the car off i rebooted tried to continue and the fans turned feul pump primed but didnt let me put a map on
    Quote Originally Posted by sxcrxy
    You turn the car off, you shut off power to the ECU...
    Nov 2011
    yes is it stuffd?
    Nov 2011
    and i could get a ecu very soon 2nd had, this will defs fix my problem right?
    Nov 2011
    can i use my exsting transponder too work with a diffrent ecu note i do not have the immobiliser instaalled
    Moderator Donkey's Avatar
    Da boonies,Va
    HELP PLEEEASE!
    Try a hard reset of the ECU by removing the neg battery cable. Hold down the brake pedal for 60 seconds to dissipate any capacitance in the electrical system.
    Sent from my magic banana
    2002 FORESTER S
    1998 FORESTER S
    Aug 2012
    Tucson, AZ
    a new ecu will work i believe...as long as that one isnt fried too
    Nov 2011
    done that still no go im getting a new ecu today should work correct?
    Aug 2012
    Tucson, AZ
    it should as long as its just the ecu, and no other elctrical damage
    Palmyra, NJ
    First rule of ECUFlash Club...do not turn off car when flashing, no matter what happens to the flashing device.
    Aug 2012
    Tucson, AZ
    what do you do after a flash goes bad and you cant turn it off? just for future reference
    Da boonies,Va
    Quote Originally Posted by sxcrxy View Post
    Yeah the 02-03's didn't have immobilizers and the alarm system is separate from the ECU.
    Quote Originally Posted by nsibanez View Post
    You try to reflash again. If that doesn't work then there are several companies that can recover the ECU but it is only for 32 bit ECU's. It's cheaper to buy a used ECU for the 16 bits than it is to pay for the reflash service and shipping to and from.
    2002 FORESTER S
    1998 FORESTER S
    Nov 2011
    well my car did come witht the immobiliser and alarm but its has been cut and removed, but since its my daily driver i didnt havve time to fix it so i went got my self a second hand ecu inc central locking, key and barrel for the transponder for $275 put a tune on it and everything is working fine its ashame what happen to my old ecu QUICK TIP TOO EVERYONE THAT FLASHES I YOUR LAPTOP CRASHES DO NOT TURN THE IGNITION OFF REBOOT THE PC AND TRY TO FLASH IT AGAIN OTHER WISE YOUR GONNA REGRET IT LIKE ME thanks guys
