Results 1 to 15 of 21
This is a discussion on Catless divorced DP with Cobb stage 2? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Searched and couldn't find much on it but I'm planning on replacing the stock DP with a catless divorced DP. ...
    Darth Dizzle Romdizzle's Avatar
    Sep 2011
    Sacramento, CA
    Searched and couldn't find much on it but I'm planning on replacing the stock DP with a catless divorced DP. Just wondering if anyone has run into any problems with this setup. Currently have SPT Catback.
    Negative pantsy rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    Re: Catless divorced DP with Cobb stage 2?
    How do you plan on tuning the car?
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    The Big 2011/2012 Mod Thread
    Sep 2011
    Sacramento, CA
    I have a Cobb ap so I was planning on just using the stage 2 map...
    Sep 2011
    Sacramento, CA
    Ps I've got a K&N intake as well. Plan on switching to Cobb SF Intake.
    Cobb notes state their map is for downpipes with a HFC only.
    Registered User DiRty Impreza's Avatar
    Jun 2011
    Canton, Ohio
    i run catless DP on my 06 with COBB AP Stage II, No issues. maps designed for a cat, but think cobb states that to cover their @$$. your car though, so whatever you feel comfortable with.
    ++ + ++P3LLA++ + ++
    06 STi ( Stage II ) BOOSTED
    HAWK-EYE ALLIANCE # 808
    Mt. Laurel, NJ
    Maps for the GR generations are more picky due to the type of ECU when compared to GDs...so it may in fact cause a difference if you don't follow the notes.
    Registered User mark012sti's Avatar
    Mar 2012
    N.H.
    Hardware Requirements: Stage2+Intake - Otherwise stock vehicle with a one of the
    supported intakes listed below., tested with a Cobb Tuning turbo-back exhaust system
    with at least one high-flow catalytic converter. An equivalent turbo-back exhaust system could be used. If the
    turbo-back exhaust system relieves back-pressure to an excessive point boost creep is possible. If a lesser
    flowing turbo-back exhaust system is used then boost targets may not be achievable. The addition of any other
    hardware may make the vehicle perform poorly.
    I found that on cobbtuning.com. It doesnt really say you need a cat in the downpipe... I was thinking of doing the same thing with my 2012. Still undecided though.. does this mean as long as you have a cat somewhere in your exhast system?? I plan on getting it pro tuned, just not sure when that will happen.
    Registered User starkall's Avatar
    Sep 2010
    When using the catless dp with the OTS map you might over boost. Especially in cold weather. My car would over boost no matter what wastegate map I used. Some cars and climates are different. It may work for you. Cobb told me it would be ok to use catless with their map but if it over boost i would have to pro tune. I'd just get a pro tune anyways. The OTS maps are mediocre in my opinion but better than stock.
    Mar 2012
    N.H.
    Ok that makes sence. Thanks for the info man I plan on getting pro tuned anyways. I should be getting my downpipe this week and then the tune as soon as I have the spare cash lying around
    Registered User Dirty Bucket's Avatar
    Nov 2011
    Augusta, Maine
    I have a 2006 WRX stage 2 with an Invidia catless downpipe, I haven't run many problems but, I have encountered very night boost creep but nothing that would harm anything.
    Sep 2011
    Sacramento, CA
    Has anyone run into or knows anyone who's had problems with a catless dp throwing codes with the stage 2 map? Just asking because I got my dp yesterday and I'm going to install it tomorrow.
    Mt. Laurel, NJ
    The AP should clear any codes related to it...but you never know. You didn't follow the map notes.
    Texas, United States
    Overboost codes are common, although I would be more concerned with the knock associated with over boosting than the code itself.
    Sep 2010
    Catless will more than likely over boost on Cobb OTS maps. Mine did. Just pro tune and be done with it.
