Grimmspeed 3 Port electronic boost solenoid
Results 1 to 13 of 13
This is a discussion on Grimmspeed 3 Port electronic boost solenoid within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Would it be worth installing a Grimmspeed 3 port electronic boost solenoid now although a tune will be 6 months ...
    Sep 2012
    Brisbane, Australia
    Would it be worth installing a Grimmspeed 3 port electronic boost solenoid now although a tune will be 6 months away?
    Is there any immediate benefits?
    Thanks
    Registered User shadowpr's Avatar
    Jan 2011
    TX, NY
    you will need a tune after you install.
    i would just wait till right before the tune if it was me
    May 2010
    Pittsburgh, PA
    Agreed on Will's feedback.
    A boost control solenoid will require a tune. It is easy enough to install, you may as well do it right before you get it tuned.
    2011 STi Build Log
            MainFrame's Avatar
    Austin, TX
    You can't drive it without being tuned, so... no.
    It's a 10-minute install. Do it in the shop parking lot when you get to the tune.
    Resident Tuner @ WTF Tuning
    Jan 2009
    Md
    Does anyone use the GM 3 ports? They are like 30.00 or something. Although Grimmspeed's customer service is definitely top notch.
    2012 WRX: TurboXS DP, AEM CAI, TP stage 2 tune
            MainFrame's Avatar
    Austin, TX
    Plenty of people have used the GM unit.. it's definitely an upgrade from our stock 2-port EBCS.
    Jan 2009
    Md
    I just had heard a lot of Evo X guys that used them over the GS... basically over price, not quality or anything. I myself am considering going back to a MBC... yes it's a dinosaur, but being able to manually bring the boost down makes me feel good in the case of the car suddenly overboosting or anything.
            MainFrame's Avatar
    Austin, TX
    You shouldn't be manually changing boost levels without adjusting the tune accordingly.
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    This.
    With the GM boost solenoid, you will need to splice into the stock wire harness. If you are to go with any EBCS, I would suggest the Perrin unit. If you really want the boost control of a MBC, I'd go with the hybrid boost control setup. Either way, I'd stay away from running an MBC alone due to PTFB conditions and the potential for damage.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Jan 2009
    Md
    No, I wouldn't either, but my point is simply that if it happens to be overboosting or anything that I can manually turn it down.
            MainFrame's Avatar
    Austin, TX
    I've heard good things about the Cobb unit as well. I personally have the GrimmSpeed EBCS and no complaints here. I'm getting ready to add a GS MBC as well and run hybrid.
    The Fruit mangostick's Avatar
    Oct 2009
    VB VA .. the ghetto on the sea
    I like that the GS part has a special bracket and looks somewhat factory when mounted. I'm going to go with one of theirs, and likely install just before I re-flash a new tune. Rumor has it I have a Phatboti tune coming for xmas...
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
